line lock for burn out and launching
Old Aug 3, 2012 | 02:10 PM
JesseJamessrt6's Avatar
Default line lock for burn out and launching
Anyone install line lock for drag burn outs and/or launcing? If so where is a good location? Any problems with error codes etc...?
Old Aug 3, 2012 | 02:27 PM
turbomar's Avatar
Default Re: line lock for burn out and launching
12 Volt LINE LOCK, ROLL CONTROL, HILL HOLDER, Great for a Temporary Brake Lock | eBay
You dont really need a line lock to do a burnout but it sure makes it easier. For better results, remove the 50A ABS pump fuse.
Old Aug 3, 2012 | 06:04 PM
The way our brake system is set up...it WON'T work. I have a new kit... Can't meake it work...so, I haven't even tried since... As I remember it, which it has been a few years, the abs is monitored by the ECU. You need to somehow get around all the sensors, which, I really didn't want to do... It isn't needed anyway...I can do my burnouts just fine, and launch just fine.... I would sell the kit cheap if you want to give it a try...hasn't been out of the box...
Old Aug 3, 2012 | 06:27 PM
thanks guys, I am trying to save my rear brake pads from the cheese grater (slotted and crossdrilled) rotors as well as have more controlled burn outs at the track, without linelock the car drifts to the side to much for my comfort yet manageable. I don't have DOT's yet but I imagine this problem will be worse.
Old Aug 4, 2012 | 01:01 PM
boostmonkey's Avatar
I make a half a dozen passes or more per week on Mickey Thompson ET Street Radials. I don't have problems going through rear brake pads. It doesn't take much brake pedal pressure to hold the car
The car doesn't walk sideways when doing burnouts either, burnouts and launches are pretty straight. I DO HAVE a Wavetrac rear end and that probably helps quite a bit. At 0* rear toe I found the rear wandered back and forth a little under hard acceleration with the drag radials. I adjusted it back in to just 1/32 toe-in and that was all it took to keep it solid.
syfi
Mar 28, 2026 04:14 PM
Mackel
Oct 16, 2015 09:03 AM
Oct 1, 2015 01:42 AM
JEFASOLD
Sep 28, 2015 12:10 PM
Selbyl
Sep 26, 2015 04:15 AM
