4 volts vs. 2 volts???
Old Aug 12, 2012 | 08:26 PM
KAMs XF's Avatar
Default 4 volts vs. 2 volts???
I'm ready to change my HU, mainly because I want built in SiriusXM and also because I'm tired of the stereo not being loud enough with the top down going fast.
I read somewhere else for the stereo to play louder I'd have to get 4 volts preamp voltage in my HU. I want to make sure this absolutely necessary as 4 volt receivers are a decent chunk of change more.
Thanks!
Old Aug 12, 2012 | 08:43 PM
Mrmiata's Avatar
Default Re: 4 volts vs. 2 volts???
I hope an amp upgrade is on your list of things to do.. "if" I'm not mistaken, 4V is to keep it at factory levels...
Old Aug 13, 2012 | 12:31 AM
bigblock427's Avatar
The stock infinity hu doesn't have preouts. The hu main-amp outs are wired to the factory amp. In other words, this is high-out to amp wiring. So if you want to use the stock infinity amp it doesn't matter if your new hu has 2 volt, or 4 volt pre-outs.
If you buy a new hu and a new amp i would strongly recommend an after-market hu with 4 volt pre-outs and an amp that can handle that,
Regards
Markus
blackpepper
Oct 4, 2017 06:09 AM
Reliableron
Oct 17, 2015 10:19 PM
AlbertFattal
Sep 24, 2015 05:03 AM
waldig
Aug 14, 2015 01:02 PM
bdh
Jul 10, 2015 11:22 AM
