HELP - Ghosts in my speakers!
Old Aug 13, 2012 | 05:45 PM
No1Piranha's Avatar
Default HELP - Ghosts in my speakers!
There are no new problems with our Crossfires, right? I hope so, and that someone figured out an easy answer to fix it. I have ghosts in my passenger side stereo speaker. Basically, white noise type static that comes and goes (mostly comes) regardless whether the radio head unit is on or off. I suppose I need to perform a stereo exorcism.
I'm assuming that the amp is powered up whether or not the head unit is on, and based upon my own very limited experience with home steareos and guitar amps it sounds like there's either a bad wire or connection from the amp to the passenger side speakers and that's causing the feedback. But I'm only guessing here. That said, I hate just taking it to a stereo shop without some idea of what the fix is. Has anyone successfully dealt with this issue? Any good recommendations for a stereo shop in the Long Island NY area?
Old Aug 13, 2012 | 07:03 PM
Default Re: HELP - Ghosts in my speakers!
I had problems with the connectors for the speakers that you access by removing the little pop-out panel at the front / top of each door.
This was when installing the capacitor mod, I had some white noise then too .....
I cleaned the contacts as best I could with emery paper and a toothpick and it went away.
Old Aug 13, 2012 | 07:08 PM
While it COULD be the connection to the speaker(s), it could also be the INPUT wiring from the head to the amp. The amp is powered up even when the radio is not "on".
Hard to say without being there to witness it.
Old Aug 14, 2012 | 11:55 PM
AlexRMC92's Avatar
a bad ground anywhere in the amp circuit could cause this too, it would allow the amp to any type of interference as a signal instead of grounding it out.
I would look at the inputs first though.
usprb1976
Apr 4, 2024 04:57 PM
blackpepper
Dec 18, 2021 06:17 PM
pioneer4x4
Mar 18, 2021 02:17 PM
nataliefs
Oct 5, 2015 01:03 PM
flame
Jul 20, 2015 08:46 PM
