oil filler tube base gasket
Old Sep 14, 2012 | 10:54 AM
csteve0355's Avatar
Default oil filler tube base gasket
The gasket where the Oil ffiller tube base meets the top of the valve cover is weeking oil. Has anyone had this same problem? Is there gasket available and if so how much and where available?
Old Sep 14, 2012 | 11:17 AM
Default Re: oil filler tube base gasket
GASKET, SEAL. Oil Fill Cap, Oil Filler Cap. (05080088AA)
Mopar Part 05080088AA OIL FILL CAP GASKET
but no guarantee anyone actually HAS it ....
( and BTW: WELCOME TO THE FORUM !!!! )
Old Sep 14, 2012 | 11:46 AM
csteve0355's Avatar
The gasket I need is the one where the aluminum oil filler base meets the top of the valve cover. Is this available or repairable or do you have to buy the whole valve cover with oil filler tube attached?
Old Sep 14, 2012 | 01:07 PM
If it is where the tube connects to the magnesium breather plate, then this is the gasket.
( same as the gasket in the oil filler cap )
If it is the magnesium breather plate leaking, there is no gasket, search the forum and you will find a DIY with pictures on how to repair that with RTV sealant.
Old Sep 14, 2012 | 01:22 PM
csteve0355's Avatar
Yes, the leak is coming from the gasket under the breather plate. Is this gasket available? If not how do you repair?
Old Sep 14, 2012 | 01:40 PM
https://www.crossfireforum.org/forum...+cover+leaking
Old Sep 14, 2012 | 05:31 PM
NeedsWings's Avatar
Oil Cap Gasket
Old Sep 14, 2012 | 10:33 PM
csteve0355's Avatar
I need the gasket that is between the breather plate and the valve cover!
Old Sep 14, 2012 | 10:35 PM
csteve0355's Avatar
I clearly see a gasket where the breather plat and the valve cover meet.
Old Sep 15, 2012 | 12:24 AM
You clearly saw a leak under the oil filler tube before, make up your mind and help is available.
Old Sep 15, 2012 | 10:39 AM
dinasrt's Avatar
Dude, you just yelled at Rob from Needswings. Hopefully you have read the valve cover link by now and understand now what alaxfire was telling you. There's no shame in being a Newbie; all of us were.
Old Sep 15, 2012 | 10:50 AM
NeedsWings's Avatar
Mercedes Engine Sealant RTV
and to make it much easier when doing this...
Mercedes Caulk Gun
Old Sep 15, 2012 | 02:54 PM
lmao.....you are so kind Rob...... Panic has set in.....omg....
Old Sep 15, 2012 | 03:10 PM
dinasrt's Avatar
Yes, funny. From another thread, I think FUBU could use those two items as well. Hopefully Rob has made a sale to Sweden recently.
Old Sep 15, 2012 | 05:36 PM
FUBU's Avatar
Ask Rob, he has a direct link to the Swedish chefs. Silverarrow and I order quite a bit. But I'll ask for the gasket at the oil filler. All other gaskets should be sent this coming week.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Darryl Camisa
Oct 7, 2015 07:10 AM
Sep 28, 2015 07:40 PM
