Stereo hasn't worked in over a year...help
Old Nov 7, 2012 | 02:05 PM
zombiehunter's Avatar
Default Stereo hasn't worked in over a year...help
September, 2011 we got a big storm, Irene. My car took on water some how and flooded the passenger side footwell and destroyed the amp. They replaced the amp and it worked intermittently for a little while before just shutting off. I replaced the headunit thinking it might be that and got sound for about 5 seconds.
I went into the footwell and jiggled all the wires thinking it might have just been something loose since it was intermittently working but I still have nothing.
Any thoughts on what to check? It's the non-gps Inifinity system. Should I try just replacing the amp? What I'm reading though makes it look like the amp does a lot more than just the sound. I just want sound again, I don't care about high end stuff stock worked fine for me. What do you recommend I replace it with?
And yes, I know I should have just taken it back to the shop when the initial stuff started happening but I didn't because I had a ton of other stuff going on it at the time. Help a brother out.
Old Nov 7, 2012 | 02:26 PM
Default Re: Stereo hasn't worked in over a year...help
You did check all the fuses, right ?
You can drive the door speakers fine with just about ANY after market head unit, it's those durn subs behind the seat that you need the amp for.
I you aren't into rattling the body work, then a good choice might be to replace the 2 subs with regular speakers, install a good $100 after market head unit and wire it all up manually bypassing the amp. You will then have left/right & front/rear fader control.
( hint: look at the marine units on crutchfield or sonic, they come in silver that matches pretty closely )
This one is $143 and it has integrated Blue Tooth : http://www.sonicelectronix.com/item_...rion-M502.html
Old Nov 7, 2012 | 02:27 PM
Lied...I fiddled and it worked for about 2 minutes and only the front speakers. I used Crutchfield's supplied harness adapter and it seems to have a lot more wires running into it than out of it.
The replacement headunit is an Alpine CDE-137BT if that matters/helps. I'm extremely frustrated at this moment and just want a car that works like it's supposed to.
I'm trying to avoid running wires and pulling interior stuff. I'd like something plug and play.
Old Nov 7, 2012 | 02:36 PM
OK.
Why don't you list your location in your profile, maybe another close-by member will volunteer to help .....
( sure sounds like an amp issue to me ..... )
Old Nov 7, 2012 | 02:41 PM
Mrmiata's Avatar
Hmm echo's from July..
https://www.crossfireforum.org/forum...placement.html
Old Nov 7, 2012 | 03:59 PM
see post today from tipad5050 - looks like you might have found a good amp !!!!!
Old Nov 7, 2012 | 09:07 PM
Sound Ordnance™ M-4050 4-channel car amplifier — 50 watts RMS x 4 at Crutchfield.com would work? And I'm in the Glen Burnie, MD area. Learning more about car audio than I ever wanted...I just like it to play music lol. Thanks for the replies.
PNA
Nov 12, 2020 04:44 PM
maxcichon
May 14, 2019 07:30 PM
Hoppy
Dec 7, 2018 07:36 AM
waldig
Jul 31, 2017 09:46 AM
Sussudio
Jul 3, 2015 10:56 PM
