Fixed oil leak, but gave up on wheel bearings...
Old Dec 3, 2012 | 11:53 AM
closer9's Avatar
Default Fixed oil leak, but gave up on wheel bearings...
My oil level sensor went out shortly after buying my car back in July. At first I thought I'd just pull the bulb for the warning light, but then found the sensor o-ring was leaking pretty bad. So, finally got the new sensor put in over the weekend. Over all I would say it was pretty easy. Didn't need to jack the car up, but did pull up on some 2x's for a little more room. So nice to drive without the light one.
Then, moved on to rear wheel bearings. My driver's side has just a little slop in it. It's not real bad, but I thought I'd get them both before they got worse. Well, the 2004 manual just says to remove the nut and remove the flange. Well, even with a hub puller I couldn't get it to budge. So, before I broke something I just put it back together. I later did some reading on a MB site about having to press the flange out of the hub. Guess I'm going to have to do some more homework, and figure out what needs to be done here. From what I've read on here and in the manual it sounded as though the axle would just push out of the splined flange, and then there was snap ring behind it, but maybe I misread that. The manual isn't always super clear about things. Plus, the 2004 manual was written for bolt in axles and my 2004 has slip in, but didn't think that would make a difference at the hub end.
Old Dec 4, 2012 | 03:36 PM
closer9's Avatar
Default Re: Fixed oil leak, but gave up on wheel bearings...
Well, after a little more reading, it sounds like I was almost there. Just need to push a little harder to get the axle out of the flange. Maybe spray a little WD40 in there and let it sit. Then the flange presses out of the bearing ID, and bearing presses out of the hub. Guess, I will try again when I have some time. Unless someone can tell me otherwise.
Old Dec 8, 2012 | 11:10 PM
closer9's Avatar
I know there are several threads with directions for changing the oil level sensor, but I didn't find any pictures. Just a few I snapped while changing mine. Over all it was a very easy job. Hardest part is getting the pan seal to break loose.
Old Dec 9, 2012 | 08:52 PM
dinasrt's Avatar
Thanks for the info. and great pic.'s. I hope I never have to do that job though, .
4drturbo
Jan 3, 2019 02:46 PM
hhr hellshotrod
Aug 17, 2015 11:27 PM
OLDawg
Aug 9, 2015 07:44 AM
Crossfireconv08
Jul 30, 2015 12:11 PM
chturner
Jul 24, 2015 04:47 PM
