Flywheel Specs
Old Apr 10, 2013 | 12:07 PM
BrandonW's Avatar
Default Flywheel Specs
So my pressure plate took a dump as my car sat in a parkinglot while I was at my kids rugby match on Saturday.
The clutch still sort of worked so I was able to limp thecar home, pulled the transmission and there it was a bad pressure plate.
Pulled the plate and clutch out and there I find a very oddflywheel.
Yes I have since learned what I can about this “wonderful”DMF but I can’t seem to find any specs for it.
My understanding is I need to check Rotational free play, and Rockbut the only spec I found in the repair manual is .003” of runout which is notwhat I’m looking for.
Does anyone know what the specs are or where I might findthem?
I don’t’ mind spending $1100 on a flywheel but to be honestwith you there are a few other parts I would prefer to spend that money on if Idon’t need a flywheel.
Thanks for any help you may have.
Old Apr 10, 2013 | 12:13 PM
sk8erjosh09's Avatar
Default Re: Flywheel Specs
Not sure on specs but our flywheels are quite hefty. The pressure plate, not so much. What makes you think the flywheel is bad? Just checking to make sure or...
Old Apr 10, 2013 | 12:22 PM
BrandonW's Avatar
That is the problem, I don’t know if it is bad or not.
I’ve got 90k miles on it so I would not be surprised it if were out of spec but while this is an easy clutch to do I would rather not do it twice and I would hate to spend the $400 on the clutch kit and then have the flywheel come apart and have to buy another one.
I figured I had a better shot of getting spec here than trying to contact a dealer
Old Apr 10, 2013 | 12:32 PM
JHM2K's Avatar
Rather than do that, call up MrMopar and ask him about the flywheel in my old car. Mine should be in perfect shape, I only had 60K on the chassis and the clutch was in great shape when the wreck occurred. Could save you several hundreds...
Old Apr 10, 2013 | 12:48 PM
I doubt this is much use at the moment but just for the record ..........(click)
Old Apr 10, 2013 | 01:17 PM
BrandonW's Avatar
Hey Guys,
Thanks for the info and ideas.
180 I did review that before I started to pull the trany and I will tell you that step 17 was extremely helpful, as it says that step is not in the manual and it is not easy to see that pin fron under the trans. That did save me some time for sure.
I will contact Mr Mopar if I do find out that my flywheel is out of spec.
As I continued my search I was able to find something. LUK makes a tool andspec sheet for DMF, in the LUK catalog they only list a clutch for our cars but they do list a DMF for the Mercedes.
The spec for the 01-04 SLK320 DMF is 17° or 7 teeth for Rotational freeplay, and 2.9mm maximum Rock
I’m not a Crossfire to Mercedes expert but does anyone think those specsshould not also be valid for our cars?
Old Apr 10, 2013 | 01:23 PM
Yes those specs would be correct for our cars also.
UNDER PSI
Nov 1, 2015 09:39 PM
Sep 26, 2015 10:21 PM
lazorouss
Sep 11, 2015 09:16 AM
firefly04
Aug 26, 2015 03:08 PM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
