P0500 - Need advice on fixing.
Old Jun 18, 2013 | 10:34 PM
Southern23's Avatar
Default P0500 - Need advice on fixing.
Hey guys,
Been searching the forums for days now trying to figure out a solution to my check engine light
My symptoms.
-P0500 problem code
-speedometer randomly malfunctions
-spoiler stuck in raised position with light flashing.
Through my searches I have found posters with similar problems but they usually had a esp/abs light on also. I haven't been able to find a thread mentioning a P0500 trouble code besides it place in the service manual and it's definition. Never a solution.
What are your guys thoughts and suggestions.
Thanks in advance!
Old Jun 19, 2013 | 02:12 AM
Selbyl's Avatar
Default Re: P0500 - Need advice on fixing.
Spoiler light flashing makes me think it could be the battery. The electronics in the Crossfire are very pickey and start to act up if it doesn't have a good source.
Old Jun 19, 2013 | 09:03 AM
Bill F's Avatar
Originally Posted by Southern23
Hey guys,
My symptoms.
-P0500 problem code
Thanks in advance!
Here is a trouble code list that was posted. P0500 Vehicle Speed Sensor Malfunction
Diagnostic Trouble Code (DTC) List - CrossfireForum.org
Old Jun 19, 2013 | 09:51 AM
Southern23's Avatar
Default
I Had found this several times but it never gave any suggestions or hints on how to fix the problem.
Old Jun 21, 2013 | 10:00 AM
SNAKEWOLF's Avatar
Look at service manual starting page 9-410.
Old Jun 21, 2013 | 06:45 PM
Southern23's Avatar
Default
I had found this also. All it showed was a wire diagram going from the abs module to the powertrain module, I believe. Wasn't quite sure what to make of it to he honest with you.
Old Jun 21, 2013 | 07:04 PM
Southern23's Avatar
Update: driving home from work and speedometer and wing are working correctly. Also noticed over the past couple days the if I shut off the car while driving then restart it when the speedometer is not working it will begin working.
Old Jun 21, 2013 | 07:58 PM
wing must work off the speed sensor....I have SRT's so I am not familiar with it, but would be my guess. That sensor or a wire to the sensor may have voltage problem throwing the code, and causing the problem. Check your connections all the way up to the fuse box...corrosion could be the problem. At least that is an easy start to look at first...
Old Jun 22, 2013 | 12:51 AM
Southern23's Avatar
Default
From what I was reading wouldn't a wheel speed sensor throw an abs/esp code too? I'm still going to check though.
franklindm
Mar 14, 2020 12:23 PM
HOT FIYA
May 31, 2019 08:01 PM
PimpDaddy
Sep 29, 2016 11:55 PM
Selbyl
Sep 22, 2015 10:41 PM
Firebombbandit
Sep 3, 2015 06:42 PM
