Door Chime won't quit!
Old Sep 3, 2013 | 07:31 PM
CindyBird73's Avatar
Default Door Chime won't quit!
HELP! My 06 has a door chime that sounds when the door is open - even if the key is out. Can anyone tell me how to make it stop or is this normal?
Old Sep 3, 2013 | 07:35 PM
Default Re: Door Chime won't quit!
Have you left any lights on?
Old Sep 3, 2013 | 08:23 PM
your rear hatch is open!
Old Sep 3, 2013 | 09:14 PM
No lights are on and no my hatch is not open. It's nothing obvious
Old Sep 4, 2013 | 12:01 AM
lildaddym's Avatar
Is your ignition working properly? If you don't hear a 'click' when you remove your key, the car thinks the key is still in, and the chime will remind you...
Old Sep 10, 2013 | 06:18 PM
belleslap's Avatar
I'm having the same problem. It started after I fooled around trying to get garage remote programed (unsuccessfully). I've checked all the latches, lights, and other obvious things. What gives?
Old Sep 10, 2013 | 06:44 PM
Do you have the steering wheel locked in position? That's the latch under the steering wheel to lock the telescoping column.
Old Sep 10, 2013 | 07:22 PM
If that microswitch is bad, I'd just live with it.
Whoa! I'd never have thought of that one.
You old Canadians are ON IT!
Old Sep 10, 2013 | 07:37 PM
belleslap's Avatar
Default
I checked that out. Door still chimes when open.
Old Sep 10, 2013 | 08:19 PM
Bill F's Avatar
I just checked mine out and the only time the warning chime comes on is when I leave the lights on or the key in the ignition. Stays on while the door is open.
Old Sep 14, 2013 | 12:16 PM
belleslap's Avatar
I have tried all the suggestions except disconnecting the battery which will happen when I put it away for the winter. I've also tried another key to see if that might trigger the switch differently. If it's just a used car gremlin attack, I can live with it. But it is a strange thing to just start up for no reason.
Old Sep 14, 2013 | 04:54 PM
belleslap's Avatar
Maybe my electric charger wasn't enough. Took a ride today and after 30 miles when I opened the door, SILENCE! That is all I can figure as I'm confident the chiming wasn't a door or light issue.
Mackel
Oct 16, 2015 09:03 AM
Selbyl
Sep 22, 2015 10:41 PM
Ed Mahoney
Sep 20, 2015 10:35 PM
xjken
Sep 13, 2015 10:18 PM
jaesa
Sep 7, 2015 01:50 PM
