Engine hesitation
Old Sep 13, 2013 | 02:24 PM
cg80's Avatar
Default Engine hesitation
In the early PM,soon after the engine is started ..when coming to a stop and the accelerator is depressed, there is a slight hesitation before the car moves??
Old Sep 13, 2013 | 06:11 PM
stryfox's Avatar
Default Re: Engine hesitation
Try a throttle reset and see if that helps.
Old Sep 13, 2013 | 07:57 PM
cg80's Avatar
stryfox: Thanks for the response... would you be kind enough to explain the full "throttle reset".. I'm have a general idea, but I don't know the particulars...Carl
Old Sep 13, 2013 | 08:13 PM
stryfox's Avatar
https://www.crossfireforum.org/forum...tle-reset.html
Old Sep 13, 2013 | 08:28 PM
cg80's Avatar
stryfox: Got it...looks/sounds simple...Thanks bunches!! Carl
Old Sep 13, 2013 | 08:42 PM
You aren't running 89 octane gas are you?
Old Sep 13, 2013 | 09:15 PM
Rets's Avatar
Is this also for the 2005 limited? Not a SR
Old Sep 14, 2013 | 01:11 PM
cg80's Avatar
pizzaguy: not using 89 octane...however really like the "finger"...very apropo!! Carl
Old Sep 14, 2013 | 01:16 PM
Mrmiata's Avatar
Why yes I actually did on CAA4.. "next gas 50 miles"... so I added enough to make a 50/50 blend with my 91 octane to make sure I got to the next station.. LOL.
Oh.. and it was actually 87.. it was all they had unless I wanted to try a little diesel blend..
Old Sep 14, 2013 | 07:56 PM
From reading previous posts on this matter it would appear that no hesitation or knocking was felt or heard.
These cars have anti-knock sensors and the timing is retarded to get rid of pre-ignition. Not good for performance but in a pinch................
Old Sep 14, 2013 | 07:58 PM
If it goes away then it is just a cold engine.
janaiy
53
Nov 2, 2015 09:23 PM
RacerXofFL
Sep 15, 2015 05:00 PM
BEATv1
Sep 10, 2015 12:58 PM
MickeyNasty
Sep 6, 2015 08:29 PM
sk8erjosh09
Sep 4, 2015 09:24 PM
