New dyno on tuesday
Old Oct 14, 2013 | 03:15 PM
velociabstract's Avatar
Default New dyno on tuesday
We need some suspense on the forum. Therefore this thread instead of waiting until after the fact. I made an appointment on the dyno that I patronize for tomorrow afternoon. Why for? It's been a while, I have a new Eurocharged tune with raised rev limiter to go along with my new Evotech TCU and I want to verify any unknown's before this weekends race. I'm looking to learn a few things. First, how much the horsepower keeps climbing over 6000 rpm if at all. Naturally, to see if the new tune found new power. The TCU is full manual in W meaning I should be able to floor it from lower rpms and not down shift. It should be interesting to say the least. What are the AFR's going to do over 6000 rpm? Stay tuned to find out how it all shakes out.
Les
Old Oct 14, 2013 | 04:03 PM
tunaglove's Avatar
Default Re: New dyno on tuesday
Evotech huh? Can't wait.
Old Oct 14, 2013 | 04:15 PM
Tension and suspense is already building.
Les
Old Oct 14, 2013 | 04:29 PM
I'll get me a big bucket of popcorn and a large Nehi grape and wait for the show to start.
O wait - maybe some chocolate covered raisins too .......
Old Oct 14, 2013 | 04:32 PM
2 hooked already! I'm ready with anti depressants as well as champagne. In other words, prepared for any eventuality.
Les
Old Oct 14, 2013 | 08:14 PM
Beaner's Avatar
Originally Posted by velociabstract
... The TCU is full manual in W meaning I should be able to floor it from lower rpms and not down shift....
Les
Very interested.........................
Old Oct 14, 2013 | 09:19 PM
grip grip's Avatar
Good luck. I have a tuned TCU in the garage, so I look forward to your results.
Oh yea, the BK guy and I are watching you.
Old Oct 14, 2013 | 09:56 PM
Bigkid's Avatar
Always interested when you have something to post Les.
Old Oct 15, 2013 | 01:04 AM
JEFASOLD's Avatar
Les
I'm betting you won't need the antidepressants, I expect to hear corks popping all the way up here in Pa. I am all atwitter waiting for the results.
Old Oct 15, 2013 | 08:08 AM
I'll do a write up on the TCU after the race this weekend. I can see it being a great help on certain tracks. (Or the dragon) The derrière dyno is meh but prior experience indicates it always reads low. Perhaps it's my spine resistors that prevent a clear signal reaching the data logger. I'm unsure what to expect. My last dyno's were with problems. Perhaps you remember the header dyno fiasco. Manifold leak fiasco, meth fiasco, etc.
Forgetting all that, TODAY IS THE DAY!
Les
Old Oct 15, 2013 | 10:19 AM
sk8erjosh09's Avatar
Can't wait to see the results!
Old Oct 15, 2013 | 11:41 AM
rayth's Avatar
The suspense is killing me tell me the results now please god
Old Oct 15, 2013 | 11:42 AM
rayth's Avatar
hmm, the forum wouldn't let me post that in all caps. loses its effect
Old Oct 15, 2013 | 03:08 PM
Here's the graph. A few notes. No correction factor, no AFR's, hot off the street and other disclaimers when I need them. They tried 2 sniffers and neither read less than 15 AFR. My wide band is giving me good AFR's so onward we went. My last dyno was 339 hp. It wasn't my highest dyno of all time but the most recent. The attached graph is the second pull. Both made the same power. The torque was lower on the pull on the graph. Heat perhaps? Both pulls hit the rev limiter. I took a video and hope to see the precise rpm it engages. 6345 rpm is for sure though. Temperature was 92º at the time of the dyno. My first ever dyno at Predator Performance was around 260 to 270 hp. 370 hp, for me, celebration time!
I'm open to critique, observations, haters, what ever you feel. Naturally easy down the road is the plan until I get some good data logs, because you can never be too careful. Oh, the gas was a 50/50 mix of 93 with 100 Sunoco.
Les
I'm looking at the graph now, WC is with correction?
File Type: pdf
Last edited by velociabstract; Oct 15, 2013 at 03:26 PM. Reason: Correction factor
Old Oct 15, 2013 | 03:38 PM
Very nice! So power keeps climbing after stock fuel cut-off, I wonder if this will be a new popular option then on tune's.
Not that it matters, but what do you think that is at the crank Les? 450 ish?
Old Oct 15, 2013 | 04:23 PM
I'd guess closer to 420 based on the drag times hp calculator.
Les
Old Oct 15, 2013 | 10:11 PM
Bigkid's Avatar
Nice flat torque curve Les bet she just keeps pulling. Did you do a pull with the cutouts open?
Old Oct 15, 2013 | 10:18 PM
grip grip's Avatar
Nice results, Les. Glad to see you're pushing the limits. That car's a beast.
Old Oct 16, 2013 | 07:01 AM
BigKid, the cutouts are a thing of the past. Long tube headers now.
Thanks Grip, I'll know soon enough how the numbers translate on the track.
Tonight an old problem with new tunes was revisited. I did a 2nd gear pull and I'm lean again. Every time I get a new tune I run leaner and I don't know why. Perhaps the ECU has to learn and adjust. I'll find some empty safe road to risk a few more pulls to confirm today.
I'd love to do some head work/better valve springs and rev this engine higher, it keeps pulling and pulling, not to mention the sound. I'll try and post up a dyno video later.
Les
Old Oct 16, 2013 | 09:05 AM
Tell me if this works or not.
Les
