Radio not working
Old Oct 23, 2013 | 09:13 PM
Truckboss's Avatar
Default Radio not working
Guys my car was used to give someone a boost and now the radio is not working any ideas...? I checked the fuses and all are fine perhaps I missed something. I checked the box next to the battery and the box on the drivers side and in the passenger compt all fuses good. Help help....! Before I take it to the dealer...!
Old Oct 24, 2013 | 06:56 AM
Default Re: Radio not working
If this is not a base model, then it may be :
1. no power to the head unit. Remove head unit and check for power at the connector.
( I am assuming this is the primary, cause you didn't say the head unit lights up but makes no sound - IIRC there is also a fuse on the back )
2. no power to the amplifier. Access the amp below the passenger footwell and check for power.
( schematics are in the online service manuals )
If it is a base model, then there is no amplifier.
Old Oct 24, 2013 | 07:58 AM
Truckboss's Avatar
Thanks I'm sorry I left out the details, no I do not have any power, and my car I believe has the amp. I have the xfinity radio head with four door speakers and the subwoofers behind the seats. The head unit does nothing. Is there any place that sells the keys to access the radio or do they have to be purchased online...?
Old Oct 24, 2013 | 07:59 AM
Truckboss's Avatar
Default
Old Oct 24, 2013 | 08:57 AM
You get the removal keys at WalMart (and probably about everywhere else.) Mine are SCOSCHE "Ford and Import" Part number DT1.
If there are speakers behind the seats, then you have a Limited (just so you know) and therefore there IS an amp under the passenger's feet.
But if the head has no power, beware there are two fuses. One is in the box at the end of the dash, one is under the hood in the big box on the driver's side. The owner's manual will give you the fuse numbers. There is also a 10 amp fuse in the back of the radio, near the wiring connectors. You may have a hard time finding a new one of those, I think it's one of the oddball-sized "AGC" type fuses.
Old Oct 24, 2013 | 02:22 PM
Mrmiata's Avatar
Location? Some of us have "spare" head units laying around.. just in case you need a test unit.. not looking to toss mine in the mail, but a local drop by could be doable..
Old Oct 24, 2013 | 02:45 PM
Harford County area of Maryland.
( in his first post )
pioneer4x4
Sep 18, 2023 11:49 AM
Hoppy
Dec 7, 2018 07:36 AM
reiji
Oct 15, 2015 10:50 PM
xzmilan
Jul 22, 2015 10:40 AM
pioneer4x4
Jul 21, 2015 10:35 PM
