3rd Brake light not working
Old Jan 26, 2014 | 03:46 AM
Bay Cruise's Avatar
Default 3rd Brake light not working
Hi Guys
Anyone have any idea why the rear window brake light may not be working, I have searched threads but all seem to be about getting it fixed. The lamp is new when I purchased the car 7 months ago so I don't suspect the led strip. All other brake lights work just not the 3rd rear window one. Thanks.
Old Jan 26, 2014 | 03:48 AM
Bay Cruise's Avatar
Default Re: 3rd Brake light not working
OK, I have check the 3rd light with 12 volts and it comes on fine so obviously there is a loose connection somewhere, are there any obvious places. Also does the 3rd lamp wiring come straight off one of the back brake lights because if so that would be a short route to check. Night time here now and getting dark so will probably carry on checking in the morning so any suggestions would be great. Thanks.
Just moved this from Electronics Thread as realised I may have put it originally in the wrong place. Sorry.
Old Jan 26, 2014 | 09:46 AM
Maybe you should move it again to 'Exterior and Lighting'. LOL
Old Jan 26, 2014 | 11:58 AM
Mrmiata's Avatar
have the service manual downloaded? Page 835 would be a good starting point..
Old Jan 26, 2014 | 05:38 PM
Bay Cruise's Avatar
Seems I have put this in the wrong place again onehundred80 !!
Anyway not to worry seems that the garage that replaced the lamp just before I purchased it joined the two cables together (why I don't know) and did a terrible solder repair right in the middle of the rubber housing between the tailgate and car which had come apart.
Off to shops to get some new wire and hopefully can pull it through and re solder where it does NOT flex. Idiots, and they were a so called prestige repair shop down in Victoria.
Old Jan 26, 2014 | 05:39 PM
Im rather impressed that they SOLDERED anything.
Old Jan 26, 2014 | 06:17 PM
You may pay top dollar at some of these places for repairs but it does not mean you'll get their top guy on little repair jobs. The former grease monkey/lot boy has to start somewhere in the shop on his rise to being a fully fledged mechanic. Let's hope some fail and rise only to the level they can be competent at. But don't hold your breath on that happening.
Old Jan 27, 2014 | 02:23 AM
Bay Cruise's Avatar
Pizzaguy and onehundred80 you are both so right. All repaired properly now and solder joined near the connector at the light and behind the left trunk covers by wheel arch. Blimey was that cover hard to get back in !!!!!!
2004_
Jul 9, 2025 12:39 AM
Roty135
17
Oct 11, 2018 10:11 AM
tom2112
Dec 1, 2015 09:02 AM
joethejeweler
Jul 7, 2015 08:58 PM
Blackout317
Jul 7, 2015 08:38 PM
