Lost Cause in Performance?
Old Apr 17, 2014 | 09:19 PM
Fero's Avatar
Default Lost Cause in Performance?
I've been flipping through this site for a while and have finally come to the conclusion that the base modeled Crossfires are a lost cause when it comes to aftermarket performance. I see a lot of talk about Mercedes engine covers, and custom exhaust and throttle bodies, but is that really as good as it gets? I'm not some wealthy tuner with endless pockets, but I know there's gotta be more options out there. I get it Superchargers and turbos are just wishful thinking, but no popular ECU mods? No Bore and stroke projects? no major parts swap tricks? please correct me if I wrong I would definitely appreciate it.
Old Apr 17, 2014 | 10:54 PM
+fireamx's Avatar
Default Re: Lost Cause in Performance?
How fast do you want to go? (I'm talkin in the 1/4 mile)?
The NA Crossfire is a 14 sec. car with a 6 spd. 15 sec. with an automatic (stock). Spend lot's of money, and install NOS, and just barely break into the 13's.
Or you can buy an SRT for a few thousand more, (than a Limited) and run low 13's (high 12's) "stock". Spend a few 1000 dollars more on mods, and run in the low 12's high 11's.
It's really that simple.
Old Apr 17, 2014 | 11:07 PM
Speedy4x4's Avatar
Default
It is a Mercedes what comes from the factory is as good as it gets. And when it time for a rebuild on motor, tranny or rear end. It is time to scrap. The alusil coating on cylinders works great but there is only one place in the world that can do it. There are NO drop in upgrades, everything has to be custom made.
Old Apr 18, 2014 | 11:51 PM
JEFASOLD's Avatar
Without adding a puffer there is not a lot to be done. The ECU tune, single intake, larger throttle body and maybe the sprint booster ( no more power but better throttle response) is about it. There's not much to be gained in the exhaust area and swapping gears can be $$$ive The above mentioned mods, maybe upgrading the brakes and suspension will make a nicely balanced car, reasonably quick, decent handling but it will never be a rocket.
Old Apr 19, 2014 | 07:59 AM
Or drop a Mercedes V8 in it.
Old Apr 19, 2014 | 09:06 AM
Speedy4x4's Avatar
Default
Ya you can drop in a MB v8. And spend 10k and get a 100 HP, with a used motor.
No point in rebuilding a mb motor, no upgrades or standard parts.
Old Apr 19, 2014 | 09:19 AM
Or be the first kid on the block to shoehorn a MB V12 into it .......
Old Apr 24, 2014 | 01:36 AM
Fero's Avatar
No doubt the Crossfire can handle its own storming out of the gate, but after 4th gear I'm pretty much bait to the 350z and others in that class. I was looking for a solution that would give me that extra edge, nothing major, but enough to give them a run for their money on the long stretch, hell a cam would be perfect.
Old Apr 24, 2014 | 07:02 AM
The EuroCharged tune ( N/A ) wasn't mentioned above. That, along with a 74mm TB and a CAI will give you more across the band.
Most here estimate maybe 30-40 HP more, and similar torque numbers, but I have yet to see a dyno of a before and after on a N/A with these improvements.
Old Apr 24, 2014 | 08:55 AM
bigblock427's Avatar
In my opinion the best and cheapest way to get more power is to sell the N/A and buy a SRT6.
We had a lot of conversions over here in germany. Btw: we have very strict emission controls. 260 HP are possible with an N/A. We've had somebody who did it (before (203 HP) and after (264 HP) protocol on a calibrated and certified dyno). But it was loads of money. There are also compressor conversions on stock N/A M112 engines which gain around 290 HP. Only useful with a MT, because the AT tranny can't handle too much torque 330 Nm (AT) vs 400 Nm (MT). And there are the V8 conversions. But all of these conversions eat more money than a change from a N/A to a SRT6.
So, buy a SRT6, or take a look at other cars.
Regards
Old Apr 24, 2014 | 09:08 AM
We have one member claiming he's close to 300 hp at the crank, 'course as you say no chart.
Jeez I forgot, in a couple of weeks a turbo will show up.
Old Apr 24, 2014 | 09:44 AM
S. Artee's Avatar
Default
Originally Posted by Speedy4x4
tranny or rear end. It is time to scrap. .
The auto?? It's just a 5G Tronic/NAG1. They're nearly as ubiquitous as wiper blades...
Old Apr 24, 2014 | 10:09 AM
Storming out of the gate a spotty face kid in a Honda with a fart can has the edge.
syfi
Mar 28, 2026 04:14 PM
Oct 1, 2015 01:42 AM
Sep 25, 2015 07:46 AM
Ralph289
Sep 21, 2015 09:34 PM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
