clicking in the rear end
Old May 23, 2014 | 08:00 PM
austinbarrylee's Avatar
Default clicking in the rear end
Please help. Today I was changing wheels and tires and noticed a clicking noise coming from the car end. I thought it was my Mandrus Milleniums I was putting on. After i put stock wheels back on the noise was still there. The noise started all of sudden and cant figure what it is. thanks very much for help
Old May 23, 2014 | 08:33 PM
RED DOG's Avatar
Default Re: clicking in the rear end
Usually this type of issue has to do with the length of the lug bolts. When installing aftermarket wheels often the stock lug bolts are too long. Are you using the stock lug bolts and the clicking occurred with both the custom wheels and the stock wheels?
Old May 23, 2014 | 08:42 PM
Well in the beginning stock rims wasn't click when driving the car for awhile. Once I put aftermarket wheels and tightened them the clicking noise started. So I took off the aftermarket wheels and put stock wheels back on the clicking noise continued but not as loud. Thanks for help.
Old May 23, 2014 | 09:25 PM
JEFASOLD's Avatar
Did you use new bolts with aftermarket wheels? If so, did you use the same bolts when you went back to stock? Grind 3/16 inch off the bolts and you should be good. Also make sure you have the correct bolt seating shape for your wheels. There is conical and ball types.
Old May 23, 2014 | 09:38 PM
I am using stock bolts. like I said there was no noise. As soon as I put the aftermarket wheels which are Mandrus Milleniums on the noise started. Continued after I put the stocks wheels can back on.
Old May 23, 2014 | 11:37 PM
rcompart's Avatar
With the new wheels, the length of both that was threaded through the hub was greater than with the stock wheels and you most certainly damaged the parking brake components. The reason they are not making as much noise now is it's just the the stuff is just bouncing around off the side of the drum vs being continuously struck with the extra length of the lug bolts.
Sorry to not have better news for you.
Old May 23, 2014 | 11:40 PM
Thanks Rudy. How do I fix. How much is this going to set me back.
Old May 23, 2014 | 11:55 PM
maxcichon's Avatar
Rudy is correct. I answered your PM to me and said the same thing.
10 minutes ago...
Old May 24, 2014 | 12:04 AM
Please tell me how to fix
rcompart's Avatar
You'll need to remove the rear rotors and determin what parts are damaged. You could be lucky and only need to buy new shoes but I'm guessing you're gonna need more than that. To remove the rotor, you will need to remove the calipers as well but you can do so without disconnecting anything, just remove the bolts, wiggle the caliper off the rotor, remove the torx bolt that is holding the rotor onto the hub and start looking at what's going on behind the hub.
Good luck and you have my number so feel free to call me Tuesday should you have any questions.
Old May 24, 2014 | 12:14 AM
grip grip's Avatar
Damn.
Thanks everyone for help. I am hoping my warranty covers it but I don't know. Sounds like this came be expensive
Old May 24, 2014 | 12:27 AM
Grip grip. DAMN IS RIGHT. That's what happens when you get work done by neighborhood redneck mechanic. Thought it was hitting the backing plate.
Old May 24, 2014 | 12:39 AM
grip grip's Avatar
I've done the face palm many times in my garage. It happens, don't be too down.
Here's what my engine looks like right now, and who's to say I won't be in a similar situation myself real soon.
Old May 24, 2014 | 12:43 AM
maxcichon's Avatar
Anthony-that doesn't go there, methinks...
I guess now would be excellent time to get the rear end set up like you had. I missed out on.
Old May 24, 2014 | 12:48 AM
grip grip's Avatar
I just PM'd Jim's son-in-law about it. Look in my recent posts and you'll see his post and contact info.
Old May 24, 2014 | 12:50 AM
grip grip's Avatar
Here you go: https://www.crossfireforum.org/forum...-bigkid-2.html
Old May 24, 2014 | 01:00 AM
I didn't wanna be rude and asked since I know he died.
Old May 24, 2014 | 07:23 AM
warranty coverage. do you all think its covered under. thanks
