Eurocharged Transmission Tune?
Old Oct 6, 2014 | 05:27 PM
power90801's Avatar
Default Eurocharged Transmission Tune?
Has anyone installed the transmission tune from Eurocharged, if so what do you think, are you happy with the results? I'm torn between the trans tune or the ECU tune, I'm only dropping the cash on one or the other. The stock SRT-6 trans is a little funky in it's habits that's why I'm considering the trans tune. Feedback would be appreciated!
Old Oct 6, 2014 | 05:47 PM
ImportLabSRT's Avatar
Default Re: Eurocharged Transmission Tune?
If you can only afford one, get the ECU tune. The TCU tune is nice to have, but not in the top 10 mod list.
Old Oct 6, 2014 | 06:20 PM
meh03's Avatar
I second that. I got Rudy's TCU tune and it helps a bit in manual mode (seems to shift faster) but all in all I didn't notice much difference.
Old Oct 11, 2014 | 07:18 PM
32krazy!'s Avatar
i had the first prototype e/c tcu tune for the m112k motor. for 6 months they tried to dial it in and eliminate the 21 far spikes between the shifts. do your homework this is a motor killer for sure
Old Oct 11, 2014 | 09:32 PM
needs to be perfected........so the ECU tune gets my vote.....
Old Oct 11, 2014 | 10:09 PM
The newest Eurocharged TCU works great in my car. There are quite a few guys on MBworld having success as well. Never had one from Rudy, so I cannot comment on his.
Old Oct 11, 2014 | 10:41 PM
So no more surprises, all good firm shifts when it is supposed too? How about re-programming for rear end gear changes? Is that a go now regardless of gear... I want to go higher than 3.27. Sorry, but these are the things to spend some $$$$$$ on. I would still go with the ECU tune first though....lol
Old Oct 12, 2014 | 02:28 AM
Da55id's Avatar
Although I have been happy with my EC TCU tune, When I floor it in 1st and 2nd, but then let off the gas just below redline in 2nd and manually upshift to third, the car won't upshift for three or four (very scary) seconds while the rpm stays at or near redline even though I've totally released the gas in an attempt to drop the revs. Is this what you are talking about Doc, or is it something else?
Old Oct 12, 2014 | 07:43 AM
32krazy!'s Avatar
are you data logging? if you are I'm betting you can see stupid high afro's during this "shift" time. i logged as high as 21 afr during these shifts
Old Oct 12, 2014 | 10:10 AM
that has been the complaints I have heard. But, Bryan puts his car thru the paces, so I listen to what he has to say. Bottom line, is what would I spend money on out of the gate. It would still be the ECU tune. Best bang for the buck. Shift points are set at WOT, so in those cases, I'm not worried about the tcu.
Old Oct 12, 2014 | 10:44 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
I have a spare TCM with the Speedriven TCM tune through Rudy and thought it was a vast improvement over stock. Crisper shifts both up and down shifting. I switch it out with my stock TCM on occasion. Only takes 10 minutes to change it.
Old Oct 12, 2014 | 10:47 AM
I have a spare TCM with the Spreedriven TCM tune through Rudy and thought it was a vast improvement over stock. Crisper shifts both up and down shifting. I switch it out with my stock TCM on occasion. Only takes 10 minutes to change it.
Now that would be the way to go, but again....he was asking which to do first. I would like to get the HP, before the shifting....I will have to look for a spare.....
Old Oct 16, 2014 | 01:17 AM
Da55id's Avatar
Ok, I spent the day doing research and found the answer. This is normal behavior for the tiptronic transmission. It has nothing to do with the EUROCHARGED tcu tune. The fix is to just let it autoshift on its own from first to second at redline. There were tons of threads fron 2006/07 detailing this behavior long before there was a EU TCU tune.
Old Oct 16, 2014 | 06:06 PM
If you are talking about launching hard and not letting it go to redline, but instead, letting off? You have that crazy I won't shift. That is normal. It thinks we are going to redline, and you confuse it when you don't lol. In fact, it can become a bucking bronco at times when this happens....
Old Oct 16, 2014 | 06:18 PM
Da55id's Avatar
Yep, that's it😀
syfi
Mar 28, 2026 04:14 PM
Apr 28, 2016 02:04 AM
steps
Oct 13, 2015 06:18 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
