Radiator Cooling fan not working
Old Jun 28, 2015 | 08:28 PM
Kmargaitis's Avatar
Default Radiator Cooling fan not working
Help pls I have replaced the radiator cooling fan and the control module and checked the fuse. And it is still not working. I have no idea y it is not working. What happen first the fan went bad the bearings gave out. so i replaced it and nothing. then the control module and nothing found the 50 amp fuse and its fine. i dont knowif there is anything else to check. PLS help
Old Jun 29, 2015 | 08:00 AM
Default Re: Radiator Cooling fan not working
Have you connected the new fan directly to 12v and ground to see if it works ?
( 12v to pin 2, black/dk green and ground to pin 1 brown/black )
If it runs OK, have you gone through all the "fan don't run" steps in 7.2 of the service manual ?
Old Jun 29, 2015 | 10:04 AM
First step - what amber alarm lights are on with the motor running?
If the Fan module is bad, you should have a little radiator-looking icon turned on in the left hand area of the instrument panel.
If the fan simply won't run and you don't have this icon turned on, I'd suspect the PTCM is crazy. ANY issue with the FCM or a blown fuse feeding the FCM should light this indicator. If the PTCM is not turning the indicator on, I'd suspect the PTCM.
Old Jun 29, 2015 | 10:49 AM
Kmargaitis's Avatar
I do not have a copy of the service manual could you tell me where to find one pls
Old Jun 29, 2015 | 10:50 AM
Kmargaitis's Avatar
What is the PTMC?
Old Jun 29, 2015 | 11:28 AM
Power Train Control Module.
It's in the box by the battery along with the RCM and BCM ( Relay Control Module & Body Control Module )
It is the board in the center.
battery -> BCM -> PTCM -> RCM
disconnect the battery ground lead, then disconnect and reconnect all the PTCM connectors, reconnect battery and see if this helps.
waldig
Jul 31, 2017 09:46 AM
hhr hellshotrod
Aug 17, 2015 11:27 PM
BrenLW
Aug 4, 2015 01:29 PM
waldig
Jul 20, 2015 08:10 AM
joethejeweler
Jul 7, 2015 08:58 PM
