Aggressive wheel rumble at 65+
Old Sep 20, 2015 | 04:10 PM
cdcrone123's Avatar
Default Aggressive wheel rumble at 65+
I've replaced all tires with new ones and changed the wheel bearing ( inner and outer) on the passenger side ( where I assume its coming from). I've got a list of things to tackle on this car since I've purchased it and this one seems to be getting the better of me. Does anybody have this problem or could direct me towards another possible problem area?
Joints seem to in relatively good shape and don't pop wheel I rotate the wheel from lock to lock...
Perhaps the steering stabilizer is shot??
HELP!
Old Sep 20, 2015 | 04:18 PM
Default Re: Aggressive wheel rumble at 65+
HELP!
I would check the wheel balancing, and if you have spacers installed I would check they are hub centric. Also, might want to look at the wheel alignment. I also would look to see if there is any tire damage, like a bulge or bad dimple in a sidewall. Good luck!
Old Sep 20, 2015 | 04:34 PM
cdcrone123's Avatar
No spacers and I was there when they balanced the tires. All was good. Although that improved the driveability, there's still something causing the wobble.. Idk im out of ideas lol
Old Sep 20, 2015 | 07:13 PM
Speedy4x4's Avatar
Default
Can you jack 1 corner at a time and Shake the wheel around, to see if that wheel is tight or if there is play, side to side checks steering, up and down ball joints.
Is your car a manual or auto?
If it is a manual, do u you feel more shaking in the steering wheel or more if you hold onto the shifter?
If it is a manual and you feel alot of vibration in the shifter, it could be in the driveline, driveshaft bearing, flex disc etc.
Old Sep 20, 2015 | 07:18 PM
cdcrone123's Avatar
Is it a manual however I don't feel it in the shifter as much. I lifted it up and when I go from side to side there's a bit of play, by play I mean more like it goes ( cluck cluck?) Up and down is as tight as can be and I can't move it at all nearly. I defiantly feel it more in the wheel towards 65+ it'll shake hard back and forth
Old Sep 20, 2015 | 07:30 PM
Bill F's Avatar
I had new wheels and tires installed awhile back. The wheels were balanced. I took the car for a drive and had excessive wobble. I took the car back and found that the right rear wheel was still out of balance. That was corrected and no problems since.
Old Sep 20, 2015 | 07:54 PM
cdcrone123's Avatar
After I had the right front changed I found an excess of green too in it. Maybe the it was the fix a flat stuff but it was puddled up. Im going to check the left front next. It will tremendously throw my balance out if there's anything in the tire lol
Old Sep 20, 2015 | 09:30 PM
Speedy4x4's Avatar
Default
A busted belt in tire will cause wobble at speed also.
Which happens with any car or tire.
Which I have had even with good years and michelin.
Old Sep 20, 2015 | 10:02 PM
Sometimes a different balancing technique can be used
Ask them to "Road Force" balance all 4 wheels and give that a try
TerryR
Dec 13, 2019 03:27 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
Oct 1, 2015 01:42 AM
Mackel
Sep 29, 2015 02:41 PM
ritous1
Sep 26, 2015 01:27 PM
