ignition switch turns but no start
Old Oct 3, 2015 | 09:54 PM
deltacrossfirebob's Avatar
Default ignition switch turns but no start
Hi......
Did the search thing and could not find the right answer.
My key turns and all electronics work but the motor no start.
HELP!!!!!!!!!!!!!
Old Oct 3, 2015 | 10:44 PM
Default Re: ignition switch turns but no start
Originally Posted by deltacrossfirebob
Hi......
HELP!!!!!!!!!!!!!
It's a pity you have a CPS that is not a genuine Bosch part as a spare. Maybe you might have needed it one day.
Old Oct 3, 2015 | 11:06 PM
I have both, the one from china that got me a refund and another that I ordered from info here.
Thanks.
Will change tomorrow.
Old Oct 3, 2015 | 11:50 PM
KDW4Him's Avatar
Thanks.
I am guessing the car cranks but does not start correct?
Old Oct 4, 2015 | 11:02 AM
Key turns the switch and all electronics work.
The motor does not turn over, just dead.
Gonna try replacing the cps as onehundred80 suggested.
Will keep ya posted and thanks for the input.
Old Oct 4, 2015 | 01:04 PM
cps..crankshaft position sensor or camshaft position sensor
I have a Bosch crankshaft sensor that I am going to replace but could the problem be the camshaft sensor??
Best seller for the camshaft sensor??
Thanks
Old Oct 4, 2015 | 06:28 PM
If the motor does not turn over at all, it is NOT either CPS, cam or crank. They do nothing until the motor is turning.
What we have here is :
1. The RCM, either bad solder joints ( MOST LIKELY ) or a FUBAR relay - search "Mystery No Start"
2. Something going on with the pulse module ( the thing that engages the starter motor, then disengages it when the motor is running.)
These problems have been found to involve the brake switch on manuals, wiring, or the pulse module itself.
The fellow over in Mississippi found it to be a wiring issue.
Old Oct 4, 2015 | 07:08 PM
In the first post you said it did not start, not that it did not turn over, crank or whatever.
Different problem now.
Old Oct 4, 2015 | 07:16 PM
stryfox's Avatar
When describing problems it is the important to give all the details.
To those who do not know may not realize how important the little details can be.
Not starting can mean lots of things.
Explain exactly what is happening and then you have a much better chance of diagnosing it the first time.
Old Oct 4, 2015 | 07:33 PM
Sorry if I did not provide enough info.
Key turns in switch, all electronics come on.
Motor does not turn over.
Finall found a scanner, and used it, code was for crank sensor.
Installed my back up Bosch and now it starts.
Now looking at having the RCM re soldered, someone here does that???
Have to find out what the FUBAR is.
Thanks for all your help
Old Oct 10, 2015 | 08:17 PM
Thanks for all your input.
Replaced the CPS, Bosch for Bosch, no junk.
Started it a few times, went nowhere just checking it out.
Went to store and......... no start, same problem.
Key turns....all electronics come on
Dtinker is doing his magic on a replacement RCM for me.
Any other ideas????????
Thanks
Old Oct 10, 2015 | 09:20 PM
Thanks
Could you check the codes again?
See if they get the same code or a new one.
Old Oct 10, 2015 | 09:49 PM
Thanks Onehundred80/
Great idea, can I write off my not thinking of it to a senior moment??/
That should have been the first thing I did.
Will do in the am and report bac.
Thanks again
Old Oct 11, 2015 | 07:59 AM
Bob, the CPS will not cause these symptoms, it does not start generating signals UNTIL the flywheel is turning.
This is classic RCM, either the 3 solder points or a flaky engine relay.
Probably not the fuel relay, as it would momentarily start, then die if that was the bugger.
Old Oct 12, 2015 | 10:30 PM
Thanks again for input.
Check to see if any codes were coming and there are none.
Guess it is the rcm??
Thanks
Old Oct 13, 2015 | 06:44 AM
I'd give it 5-1 Vegas odds
Old Oct 20, 2015 | 03:38 PM
Hi all....
Just a update.
DJ did his magic on my rcm and all seems ok.
Thanks again to DJTighe and also to all the other input I received.
This forum rocks!!!!!!!!!!
Nov 11, 2015 05:22 AM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 21, 2015 10:58 AM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
81's
Sep 13, 2015 04:34 PM
