Throttle Position Sensor?
Old Oct 19, 2015 | 04:34 PM
Brady517's Avatar
Default Throttle Position Sensor?
Alright, so the problem is when the pedal is pushed down the car will jerk quite often. From time to time it will even jerk once or twice, and shut down. All of the electronics will remain functional, but the engine is off. I've replaced the cps as someone informed me that may have been the issue.. well, it wasn't. Anyone had similar problem?
Old Oct 19, 2015 | 05:56 PM
Default Re: Throttle Position Sensor?
The TPS is integrated into the throttle body on Crossfires.
You can remove the black plastic cover and spray some electronics contact cleaner on the wiper fingers and the board while manually moving the butterfly back and forth.
You may have any number of problems :
gas pedal assembly
throttle body
fuel pump
fuel filter
fuel relay in the RCM module
intermittent electrical connection somewhere
You can monitor the fuel pressure at the test point on the injector rail, 55-60 PSI.
Old Oct 19, 2015 | 06:14 PM
Despite the jerking, can the car be driven at higher revs or is it unable to do anything beyond idling?
Old Oct 20, 2015 | 01:53 PM
Brady517's Avatar
It can be driven at higher rpms
Old Oct 20, 2015 | 03:36 PM
It could be nothing more than a loose fitting from the air cleaner, or the CAI if you have one, to the TB.
Or the TB itself loose on the manifold intake.
Our cars are so technical sometimes we overlook simple. Sometimes a cigar is just a cigar.
Old Oct 20, 2015 | 04:28 PM
Brady517's Avatar
So I ran the check engine light, and the crank position sensor, throttle position sensor, and an O2 sensor came up. Any idea where I can get a throttle sensor? My local auto parts stores don't carry them, and I have been unable to find one online for some reason. Thanks for the suggestions.
Old Oct 20, 2015 | 06:00 PM
Like many of the parts on cars these days they are replaced as a unit, so no TPS spares.
The CPS has been found to have a weakness in the fit to the connector that goes to it, also make sure you have a Bosch CPS as other have caused problems. Make sure the connector is a tight fit on the CPS and there is no problem with the connector.
One problem an cause multiple codes to be written, solve one and the others are solved miraculously.
Old Oct 20, 2015 | 09:24 PM
Codes come because something in the programing doesn't come through right. it could be the sensor or just the program faults because "something didn't go right. Keep in mind the Sensors can only tell what "DIDN"T" happen as planned.
As 180 suggested one thing can produce several codes. I get a2 02 code when the car goes lean onece in a while. E light comes on and despite replacing that sensor I still get it.
But the interruption in the throttle could just as well be an intake leak as a sensor malfunction or an actuator malfunction. Before I replacing sensors and actuators, I simply suggest making sure the plumbing is patent. Sometime the sensor isn't wrong, it's just sensing something wrong.
Not theory or a guess. When my roadster does exactly what your symptoms suggest, I often find the CAI has a loose joint. So poke around the cheap and free solutions before you buy parts.
Old May 18, 2018 | 05:37 PM
cobra1951f's Avatar
I get a p122 code throttle position sensor when i start in the morning, I clear the code after start up and doesn’t bother for the rest of the day driving ?? Any suggestions?
Old May 18, 2018 | 10:07 PM
Steve Jr's Avatar
Seafoam an WD-40 to start with..
Sterling57
Apr 11, 2016 06:11 PM
Mark SRT6
Dec 17, 2015 04:24 PM
massanu
18
Nov 23, 2015 08:52 AM
nickwe21
Oct 9, 2015 12:45 PM
Den656
Sep 23, 2015 12:27 PM
