How do I remove the weather strip retainer?
Old Dec 30, 2015 | 11:53 PM
Blackktieguy's Avatar
Default How do I remove the weather strip retainer?
Hi!
I've experience a leak in my car and am looking to purchase a new d-side retainer for the car. I however -- don't know how to take it off.
Any insight on this is greatly appreciated.
Thank you.
Old Dec 31, 2015 | 07:33 AM
Default Re: How do I remove the weather strip retainer?
Originally Posted by Blackktieguy
Hi!
Thank you.
I may be particularly dumb at this time of day but what do you mean. I'm guessing the door but .......?
Old Dec 31, 2015 | 04:05 PM
These are the pictures.
Old Jan 1, 2016 | 09:44 PM
Anybody care to give a guy a hand on the uninstall for this?
Old Jan 1, 2016 | 10:22 PM
Is this part damaged? If it leaks it may be because the window does not seal
against the seal properly. The window can be moved against the seal, up and inward if required and it would be a lot easier than fitting a new seal which may not be required.
Old Jan 1, 2016 | 11:57 PM
The actual seal is somewhat damaged by the leaking area. It needs replacing. Also -- for future reference, how would I go about adjusting my window? Via inside the door panel?
Old Jan 2, 2016 | 11:06 AM
I did this PDF on window adjustment some years ago. CLICK
I'm guessing that the part of the seal above the door is glued on, that's what it looks like when I study mine.
When the door is closed the top of the glass hits that seal, moves it out the way and the seal comes down again to affect a seal on the edge of the glass.
Old Jan 2, 2016 | 03:39 PM
I guess I'll replace the retainer since I already bought it. Know some good glue to use for fitting the retainer in?
Old Nov 25, 2025 | 11:49 AM
gualtira's Avatar
It appears that there are small torx head screws to remove.
Old Nov 25, 2025 | 01:49 PM
10-year-old post.
cjfine
May 12, 2024 06:45 PM
getshawty
Dec 1, 2020 08:03 PM
Valk
Dec 22, 2015 05:18 PM
leaddog2015
Dec 10, 2015 02:19 AM
Kowmander
Dec 5, 2015 08:36 PM
