Electric fan question?
Old Jun 3, 2016 | 05:46 PM
srtmodder's Avatar
Default Electric fan question?
Just for sh*^s and giggles does anyone know the cfm that the stock electric fan pulls? I was just wondering if there is a universal I could buy to replace that pulls stronger. I'd leave it running all the time since being in Texas heat is always an enemy. Plus just the thought of a massive beast of a fan I always like.
Old Jun 4, 2016 | 01:33 PM
Default Re: Electric fan question?
It amazes me that 100/80 hasn't grabbed his slide rule (I know he owns one), measured his fan, estimated rpms for full speed - and posted a calculation that is within 10%.
I've been waiting, Dave. Where you been?
Old Jun 4, 2016 | 01:47 PM
LOL, I snapped my slide rule in half, then used my fingers and toes.
Surely the CFM would be quite a variable number, dependent as it is on fan RPMs, altitude, temperature ?, grille design and vehicle speed.
I'll go with the scientific answer and say quite a lot to very little.
Old Jun 4, 2016 | 02:04 PM
More than a spring breeze, less than an Oklahoma tornado.
Old Jun 4, 2016 | 05:49 PM
dinasrt's Avatar
Not sure if you've ever heard your fan @ 100% or not, but when it needs to, it spins like a turbo prop. I can't answer your question about CFM, but I believe our fan is up to the task when it is told to by the controller. I've run autocross in 105deg.heat and never climbed past 206deg. ECT, even after heat soak at the end of the day. If you haven't already, remove the rear hood gasket to let some heat escape. You can also run a more diluted coolant in the summer (25%/75%)for example, for better cooling. I run 100% distilled water and a bottle of Water Wetter from Needswings in my IC circuit most the year round since we rarely freeze here, but I do add/mix a little antifreeze in if we expect a freeze.
Old Jun 6, 2016 | 11:08 AM
srtmodder's Avatar
Thanks for the tip. Yeah I've been running the recommended from the factory and think I may be able to get it a tick cooler by running mainly distilled water. I just remember past vehicles and running an aftermarket one and it helped but that was mainly because the original was belt driven.
I would you a killer chiller but being in Houston the A/C is very much needed at its peak performance!
doggboy
U.K.
Jun 22, 2016 04:19 PM
Danvelo1
Jun 3, 2016 05:03 AM
BibaResto
Jun 3, 2016 03:31 AM
texas t
May 31, 2016 05:05 PM
BibaResto
May 20, 2016 03:28 PM
