Brake light work only when headlight are off
Old Feb 26, 2018 | 02:25 PM
jt2005crossfire's Avatar
Default Brake light work only when headlight are off
Several weeks ago I had a minor accident that involved a guide wire (fence) breaking my two front headlights and grill .I drove the car home after the accident and my BAS/ESP light came on later in the week I replaced the headlights and bulbs. The BAS/ESP light remained on afterthe repair. I tried to reset severat times by turning the steering wheel as directed in the fourm. The brakes lights function correctly when the headlight switch is in the off position BUT when I turn the headlight on the brake light do not function correctly. ( I believe they stay on).
2005 crossfire
74k
no other known issues
Old Feb 26, 2018 | 03:39 PM
Default Re: Brake light work only when headlight are off
2005 crossfire
74k
The brake lights and the BAS/ESP problems are connected and have nothing to do with the headlights. I would suspect a brake switch problem, this may just be a coincidence.
Old Feb 26, 2018 | 08:14 PM
How can we help you if you can't tell us what the symptom is?
You say all is well with lights off. Ok, got that.
NOW:
You turn light on and what happens:
--- The brake lights come on and stay on. (ICM I would think.)
--- The brake lights come on when I step on the brakes, but then won't go back off. (This would make me think there is some odd screw-up that is "latching" the brake light relay, looking at the wiring diagrams [which are incomplete and not totally accurate] the only thing I can come up with is the Antilock Controller module - but I just don't see how.....)
The CLPSSM is wired to the tail lights thru diodes, don't see how that could be it...
Old Feb 26, 2018 | 11:35 PM
NOW:
Too many times we have seen symptoms lumped together and then found they were caused by different problems. Another cause of rear light problems has been the use of the wrong bulb in a socket causing problems.
wootto
U.K.
Aug 16, 2020 07:55 PM
dobermann
24
May 8, 2018 01:19 AM
nickwe21
Feb 18, 2018 12:59 PM
AlexParra
Dec 9, 2013 02:10 AM
blackoutken
Jan 25, 2012 11:21 AM
