will not run, help please
Old May 17, 2018 | 11:05 AM
len watts's Avatar
Question will not run, help please
I laid my 2005 roadster up for a year, just fitted new battery and car will crank but not start. The only way to get the fuel pump running is to manually trigger the fuel pump relay which will start the car for a few seconds. As I have fitted a new battery could there be something influencing the relay other than a bad relay or board
crossfire has done no work just 5000 miles. help
Old May 17, 2018 | 03:00 PM
Default Re: will not run,help please
try the fuel filter/regulator they are both in the filter housing, if that is gummed up, yet you are forcing fuel through ,,that would only let the engine run until it ran out of fuel.
Old May 17, 2018 | 03:30 PM
Padgett's Avatar
The proper way to start is with a pressure gauge on the fuel rail. Should have over 30 psi to idle. If the fuel pump relay then a good chance you have a bad RCM (relay control module). Common problem.
Old May 18, 2018 | 10:55 AM
len watts's Avatar
no pressure on rail unless i trigger relay by hand.i have just ordered a gauge to read pressure.
Old May 18, 2018 | 01:49 PM
Default Re: will not run, help please
A bad solder joint on the RCM?
You say manually trigger the relay, do you mean continuously or just for a few seconds?
Has a fuse blown on the RCM?
Has a fuse blown in the main fuse box?
Old May 18, 2018 | 07:39 PM
len watts's Avatar
fuses look good, operate fuel relay by finger so to here pump runnig,car will then crank and run for a few seconds.solder joints look ok. car only done 5000 miles.
Old May 19, 2018 | 12:23 AM
tighed1's Avatar
If the fuse is good and the car starts/runs while you are forcing the contact closed on the fuel relay, the relay is bad. I can replace it and do other repairs on the RCM for you. $30
If interested email me at tighed1@hotmail.com for details.
Old May 19, 2018 | 10:01 AM
len watts's Avatar
Hi,i live in the uk and i am checking the shipment costs.I am wondering if i might be able to do the repair myself.can you please give me more info on the relays (make part number etc)
I have just noticed that the rear spoiler stays up, can this be due to same problem?
It might be that i will have to ship to you.
regards
Old May 19, 2018 | 06:09 PM
Steve Jr's Avatar
Check your battery! Spoiler coming up on startup is classic bad battery...
Old May 19, 2018 | 08:22 PM
len watts's Avatar
I have just noticed that there is no movement on rev clock when cranking motor?
Old May 22, 2018 | 06:14 PM
better listen to Tighed1...
Old May 22, 2018 | 08:08 PM
I' don't believe that the tach registers anything during 'cranking'.
Based on your opening post, you already have diagnosed the problem, the fuel pump relay is bad. Change it or change the entire Relay Control Module. (Or yank the RCM and send it to Tighed1).
Old May 22, 2018 | 09:50 PM
Not sure on the Crossfire, but others I have worked on will show rpm while cranking.
James
Old May 22, 2018 | 11:59 PM
Agreed, the tach does not move until the engine starts operate under its own power.
stz561
21
Nov 29, 2016 11:55 AM
ardenian
Nov 4, 2016 12:37 PM
pizzaguy
Crossfire Events and Meets
17
Sep 26, 2016 10:54 PM
pizzaguy
Sep 24, 2016 07:59 AM
rmaier
Aug 1, 2016 07:43 PM
