RCM or CPS problem
Old Jun 13, 2018 | 11:33 AM
firefly04's Avatar
Default RCM or CPS problem
I am looking at an 04 crossfire manual that has a no start issue. I already have an automatic and absolutley love my car! The manual is having the no start issue. All the dash lights come on but he thinks there is no power going to the starter. He claims the car will crank if pushed off in 4th gear. Does this sound like an RCM problem or CPS? Thanks in advance for your help.
Old Jun 13, 2018 | 12:56 PM
Default Re: RCM or CPS problem
First, turn the key to "ON' and wait 30 seconds. Does the engine fan run at warp speed? If so, the engine control relay output from the RCM is bad - and the car would not start in this case no matter what you do.
SO, Make him prove that. If it starts, the car needs a pulse module, starter or starter solenoid.
Old Jun 13, 2018 | 01:27 PM
firefly04's Avatar
Thank you for your help. I definately want to make sure the car can crank in 4th like he says before purchasing. I had issues a few years ago with my automatic and ended up having to replace the crank sensor and later the RCM. But I was unsure of this new car being a standard and all. Does the pulse module go by another name? I am unable to pull it up at the parts store online. Thanks again.
Old Jun 13, 2018 | 01:40 PM
The student reference and the service manual both call it a pulse module. But I've only seen one PM fail in the nine years I've been in the group.
Also, there are two pulse modules:
  • One for Automatics that enables "turn to start" for autocranking.
  • One for Manuals that enables no "turn to start" for autocranking.
Both models arbitrate the signals from the key and ECM to cut out the starter at 400 rpm (when the engine starts).
Old Jun 13, 2018 | 04:13 PM
I have a 6 speed manual and recently confirmed that the manual does not have a "pulse module"
Only on automatic models
Old Jun 13, 2018 | 05:23 PM
^^^^^^ Agreed.
Old Jun 13, 2018 | 07:47 PM
Take a picture and show us your manual pulse module Mark.
We seem to have a bit of contention here.
Old Jun 13, 2018 | 08:18 PM
But the pulse module takes an enable from the PCM and the input from the "Start" position on the ignition and engages the starter, when the enable from the PCM goes away (at 400 rpm), the starter cuts out. IF I have no pulse module, how does the starter cut out?
I know the service manual is often not accurate, but....
Old Jun 13, 2018 | 08:20 PM
I will do that - but I won't see my car again untill June 22nd.
Old Jun 14, 2018 | 10:35 AM
If you cannot get the starter to operate with the engine running then you have a pulse module in the manual transmission cars.
I had a six speed and I think that you could not get the starter to operate with the engine running, so I will say that the PM is in the 6 speed models.
Old Jun 14, 2018 | 12:08 PM
Mrmiata's Avatar
I'm going with "yes they have a pulse module" and doesn't have connections on the end port like an automatic does..
Old Jun 14, 2018 | 07:39 PM
firefly04's Avatar
Thanks for everyone's insight. I am looking at the no start car tomorrow. Now the guy is telling me it doesnt start at all. All the dash lights come on, but when you turn the key the lights go out and no start. Going to buy the car regardless of the no start, it's in great shape. I am hoping its the RCM, tighed just fixed my broken one for me 😀
Old Jun 14, 2018 | 08:18 PM
Steve Jr's Avatar
Pull your RCM an take it with you. Cant hurt an will eliminate that...good luck..
Old Jun 14, 2018 | 10:58 PM
The last thing you would want is to prove that the car is easy to start, that would result in an lmmediate price increase.
Old Jun 15, 2018 | 02:08 PM
firefly04's Avatar
Just looked at the car, put my working RCM from my car in it but didnt fix the issue. He said he replaced the CPS a few years ago from local auto parts store. When you turn the key the starter clicks, but the car does not turn over. Not giving up on the car yet. Any other suggestions?
Old Jun 15, 2018 | 02:18 PM
Have you checked for a good ground from battery to car frame, and also ground cables from frame to engine ?
Do this : connect between negative battery terminal to engine block with multimeter on ohms scale.
It should read real close to 0 ohms.
Old Jun 15, 2018 | 02:47 PM
Try your battery or jump the existing battery. Could be a battery problem.
Old Jun 15, 2018 | 04:09 PM
THe price just dropped.
Old Jun 17, 2018 | 01:22 PM
firefly04's Avatar
The price definitely dropped Without the car cranking I have no idea what shape the motor or transmission is in, a big gamble for me. You know I didn't even think about the simple fix of a bad battery. I guess I had a girl moment lol. He did have the battery disconnected when I got there. And I might have been more clear in my last post about the starter clicking. It only clicked once then silent and all dash lights go out, it was not a repetitive clicking. I plan on looking at the car again later this week. Hopefully he'll accept my offer this time and I can just wench it on the trailer and take her home to work on.
Old Sep 11, 2021 | 03:22 PM
Icewrench's Avatar
PATS problem. I don't exactly remember much about it so I won't be much help but I had an 05 limited roadster 6sp same problem. Hope this helps.
28
Aug 26, 2021 01:05 PM
Hal B
Sep 18, 2016 04:02 PM
victorlautreamont
Jul 13, 2016 07:50 PM
nick78ru
Jul 16, 2013 09:22 PM
GDrag
Aug 24, 2012 02:50 PM
