Overheating?
Old Aug 28, 2019 | 03:37 PM
evilsaint's Avatar
Default Overheating?
So I bought this crossfire , a 2005 base convertible 6 spd . Occasionally , while driving , the "check coolant temp" comes on the display with a beep . It will stay on for a while then go away . The gauge seems to work properly ( starts from bottom and works it's way up to 1/2 or just slightly over in a reasonable amount of time) and according to the gauge it's fine . Coolant is full and burped . Upon physical inspection , it doesn't "seem hot." Fan works as it should . Any ideas? CTS was my thought ...
Old Aug 28, 2019 | 08:17 PM
Default Re: Overheating?
Originally Posted by evilsaint
while driving , the "check coolant temp" comes on the display with a beep.
Are you sure? I've been an owner of three Roadsters and a member here for ten years. I've never heard of a text message in the display of the panel, other than the "Start Error" message when a SKREEM acts up or the "HI" when you overfill the oil level.
Dave, George, Greg? How did I miss this?
Old Aug 28, 2019 | 09:57 PM
evilsaint's Avatar
I didn't make it up ...
Old Aug 28, 2019 | 09:59 PM
evilsaint's Avatar
To be clear , it's the "check coolant temp" icon , as opposed to the coolant lo icon , the text says , "Hl"
Old Aug 28, 2019 | 11:20 PM
No, you aren't making it up, the issue here, I think, is that you are making an assumption that is not correct.
The owner's manual explains this:
Unfortunately, the manual is probably the cause for this. Someone read the manual and put in 8 1/2 quarts of oil at the last change. The required fill is 8 quarts.
From the often-inaccurate manual and misleading owner's manual you get the wrong message:
Old Aug 28, 2019 | 11:25 PM
evilsaint's Avatar
It replaces the trip odometer , the check coolant temp icon and the text HI . It beeps once when it comes on .
Old Aug 28, 2019 | 11:36 PM
Yea, like I said. That's the oil level alarm.
Old Aug 28, 2019 | 11:39 PM
evilsaint's Avatar
That sounds way better. Oil change it is. Thanks!
Deborah Walker
May 15, 2010 05:00 PM
2005crossfire6speed
Apr 7, 2010 06:28 AM
CALL911
Sep 3, 2008 12:11 AM
lioninavette
Jun 9, 2008 11:25 AM
Ed
Sep 9, 2005 09:41 PM
