removing shifter knob
Old Jul 5, 2005 | 12:15 PM
kwiktsi's Avatar
Default removing shifter ****
I tried to remove the shifter **** in my wife's crossfire (yes, we bought two the same week. lol) to inspect it- think it is cracked internally, it makes a cracking sound when shifting. Anyway, I pulled the boot and loosened the "cone shaped" nut on the **** and tried to pull it off with no luck. I didn't want to force it in case I missed something- is there anything else to remove? Thanks.
Joe
Old Jul 5, 2005 | 01:53 PM
former NXMX5's Avatar
Default Re: removing shifter ****
nope. just wiggle and pull. if the nut is completely removed, it should come off; might take some effort --
Old Jul 5, 2005 | 02:10 PM
kwiktsi's Avatar
Thanks- I'll remove it tonight and inspect it. Has anyone experienced a cracked or "creaking" shifter ****? It is the **** itself- you can "rock" it back and forth on the shifter a bit and it makes a creaking/popping noise as it moves.
Joe
Old Jul 5, 2005 | 04:58 PM
my stock shifter was always tight. my MOMO became loose because i used the wrong insert, so it started to rock after about a month or so. i've since redone it with the right insert and its solid again --
if your stock **** is rocking, i would definitely take it off and try to reinstall the right way. or, worse case, you'll have to head over to the dealer. (best case... get a momo )
Old Jul 5, 2005 | 06:05 PM
jjarocki's Avatar
Anyone know how to remove the A/T ****?
Old Jul 5, 2005 | 06:40 PM
chxf's Avatar
It's very easy. Underneath the **** there is a retainer nut. Rotate it and remove it from the ****. Than just pull the ****. That's it.
Old Jul 5, 2005 | 07:54 PM
Dan Root's Avatar
Banned
Talking Re: removing shifter ****
Checkout www.TUGJOB.com!!! pull alittle harder!
Old Jul 5, 2005 | 08:32 PM
chxf's Avatar
Yes, I checked but I can't find the retainer nut! Maybe it's hidden by the mechanic hands.
Old Jul 5, 2005 | 11:43 PM
Dan Root's Avatar
Banned
Exclamation Re: removing shifter ****
Originally Posted by kwiktsi
I tried to remove the shifter **** in my wife's crossfire (yes, we bought two the same week lol) to inspect it- think it is cracked internally, it makes a cracking sound when shifting. Anyway, I pulled the boot and loosened the "cone shaped" nut on the **** and tried to pull it off with no luck. I didn't want to force it in case I missed something- is there anything else to remove? Thanks.
Joe
You might want to take it in to your dealer because the shifter (manual) has been known to POP-OFF while in use! A dealer prep problem!
Old Jul 6, 2005 | 10:45 AM
Elitewarz's Avatar
Hey I'm interested in changing the shift **** myself. Just wondering if dealership will give you a problem about changing it and does it affect the shifting or cause problems when driving. Example the reverse pulling the **** and shifting or shift **** giving driving problems? Thanks.
Old Jul 6, 2005 | 11:34 AM
kwiktsi's Avatar
Dan- thanks, I wasn't aware of that. However, I try to avoid the dealer whenever I can. Its more headaches than it is worth, I have been a mechanic/tuner for about 17 years now, so I do what I can, before going to the dealer. I will probably end up getting a new shift **** under warranty and putting it on, I have a feeling it is cracked inside.
Joe
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
