Turns over but doesn't start
Old Oct 8, 2020 | 07:13 AM
Mike_man458's Avatar
Default Turns over but doesn't start
Hey fellas I'm new to the famous crossfire website.i have a 05 crossfire convertible limited edition an I'm having problems with it starting I was wondering if anyone has any idea why please let me know I would appreciate it
Old Oct 8, 2020 | 08:09 AM
Default Re: Turns over but doesn't start
#1 cause of cranking but not starting is the CPS. Have you tried that ?
Old Oct 8, 2020 | 02:18 PM
tighed1's Avatar
Any fault codes? CPS will generally give codePO335.
Turn the key to the ON position and wait 30 seconds. Does the radiator fan spin up REALLY fast?
Old Oct 9, 2020 | 07:01 PM
yea I changed both crankshaft position sensor and camshaft position sensor an still nothing I looked up on YouTube that wen u put the key in an try to start it it will turn over but want start then I'll do it again an it will do it again now the third time I try to start it there's nothing like it want even turn over people are saying something about a skreem module well I took it out an waiting till I have enough money saved then I'll buy a new one it's like $730
Old Oct 9, 2020 | 07:05 PM
Yea I changed both crankshaft position sensor and camshaft position sensor an still nothing and I checked the fuel was good and spark is good an I soldier the three points in the box by the battery an still nothing I don't know ANYMORE
Old Oct 10, 2020 | 11:48 AM
No, it does not cost $730 because you cant get them anymore. What you CAN do, is yank the ECU, SKREEM and pack them with a key and send it all off. The ECU can be set up to ignore the SKREEM. SOS Diagnostics and Needswings can both do the work.
Contact each and see what they charge. Perhaps it IS $700 but I was thinking the "SKREEM Bypass" was less expensive than that. Contact the two companies, ask, don't go by what others say, even me.
treborppal
Sep 8, 2012 03:42 PM
Smokin Red '06
May 24, 2012 05:46 PM
sue.d
Jul 18, 2009 03:45 PM
jjg
May 31, 2009 06:34 PM
psuperti
Racing
Mar 14, 2009 07:13 AM
