I found this part to be the cause of the erratic climate control fan speed
Old Mar 5, 2021 | 04:32 PM
Tomcross's Avatar
Default I found this part to be the cause of the erratic climate control fan speed
When I would turn the fan speed ****, I found the speed to to be erratic. So, I took the unit apart and discovered that the shaft connected to the back of the fan control **** rotated a little variable resistor. I connected a ohm meter and turned the resistor instead of being a linear rise or fall, the needle on the ohm meter, was erratic just like the fan speed.
I think the resistor directly controls the voltage to the climate control fan. I removed and replaced the resistor with a new one on two separate units and the both worked perfectly.
Please see picture attached of the troublesome part.
MODERATOR NOTE:
If putting the module back is a problem due to difficulty in aligning controls, click here and read post #4:
https://www.crossfireforum.org/forum...alignment.html
Old Mar 5, 2021 | 05:15 PM
Default Re: I found this part to be the cause of the erratic climate control fan speed
What is the full part number for the resister?
Old Mar 5, 2021 | 06:32 PM
if u fix them $$$ I will send u mine, jim
Old Mar 6, 2021 | 10:55 AM
Tomcross's Avatar
This is what is marked on the part Piher Spain 4k7428me
Old Mar 6, 2021 | 12:38 PM
maggy55's Avatar
I believe these are the same . Maybe someone can confirm that. If I bought 10 of them would anyone be interested in buying the extras off me . I think it would come out to about $3 each, including shipping.
https://www.ebay.com/itm/Piher-PT15N...F/254873150145
Old Mar 6, 2021 | 12:40 PM
JSK's Avatar
JSK
Yes, I would take one or two.
Old Mar 6, 2021 | 12:47 PM
I will take 2 also. PM me with $$$ and paypal address.
Old Mar 6, 2021 | 12:52 PM
maggy55's Avatar
Looks like there's some interest, so I ordered 10.
Old Mar 6, 2021 | 12:59 PM
Toolman's Avatar
Great diagnosis and part find!
Old Mar 6, 2021 | 01:22 PM
Electrically, that is probably the part. There are two kinds: Linear taper and audio taper - we want linear taper. If it's an audio taper, the entire fan speed range will be in between two fan switch positions instead of five. Usually, a linear taper is assumed unless specified otherwise, hence I think it's the right part. Piher's product pages describe many such pots with a "PT1Nxx" series part number, all of them are described as "linear taper" - so I think it's the right part.
Physically, it may not quite fit, but I suspect you could spread/contract it's solder-legs and make it fit, provided the shaft from the control fits the hole in the center, and if not, a simply modification with a file may do the job. There are a handful of "PC mount pot" sizes but they don't vary by much.
Old Mar 6, 2021 | 01:23 PM
This thread is worthy of pinning.
DONE.
Old Mar 6, 2021 | 01:27 PM
Great find, this might just be the fix for the erratic fans on our cars. I believe I'll hold off on my one, thanks for understanding.
Old Mar 6, 2021 | 02:17 PM
Ronman's Avatar
Where did you buy a replacement from?
Old Mar 6, 2021 | 05:14 PM
BobG's Avatar
I'll take one or two if there's insufficient demand by others. I can send you PayPal.
Since I already replaced the resistor pack some years ago and still have erratic behavior, it would be interesting to see if this inexpensive variable resistor is the source of the problem.
Old Apr 8, 2021 | 12:46 PM
maggy55's Avatar
Hi, received the resistors. Have 10 available at $3 each, includes shipping to US. I have not taken my climate control apart to verify fit. Paypal email is maggy_94928@yahoo.com.
Old Apr 8, 2021 | 01:02 PM
BobG's Avatar
Just sent you $3 by PayPal. If PayPal didn't provide my address, let me know and I will send it to your yahoo email.
Thanks
Old Apr 8, 2021 | 01:24 PM
flaco1801's Avatar
Hi Maggy Can i purchase (2) of them?. i can send you 6 dollars paypal if you say yes....thank you....Jeff
Old Apr 8, 2021 | 01:29 PM
maggy55's Avatar
That would be fine
Old Apr 10, 2021 | 01:34 AM
That would be fine
Just sent $3.00, Thanks Maggy!
Old Apr 10, 2021 | 01:36 AM
Does any one know if there is a tutorial for this replacing of this part, yet? Have looked but have not run across one.
