Emissions: "Not Ready"
Old Aug 7, 2021 | 12:10 PM
jjohn's Avatar
Default Emissions: "Not Ready"
purchased car in fla..the car failed inspection in n y.... evap and catalytic failed....i drove for 250 miles at hwy speeds..still failed ..any help would be appreciated
Old Aug 7, 2021 | 12:25 PM
Default Re: new york inspection
Driving at one speed does not get the job done, mixed driving speeds does it, I can get mine done in 20 miles of steady town speeds varying between 20 and 40 mph and a return on the highway at 50 mph. No rapid acceleration just plodding along. There is a thread on how to do it on here or just Google for the Chrysler emissions test.
Old Aug 7, 2021 | 01:16 PM
JSK's Avatar
JSK
Did it fail because there were codes or because it was not ready to test? Makes a difference, if there are codes you will have to make the repairs. My coupe has twice failed because it wasn’t ready (battery disconnected before test) and required a drive cycle.
Old Aug 7, 2021 | 01:30 PM
jjohn's Avatar
hi it was not ready....what did u do for the drive cycle
Old Aug 7, 2021 | 01:34 PM
Good point, I was only thinking of the drive cycle.
Old Aug 8, 2021 | 11:10 AM
If it is truly just "Not Ready", just DRIVE THE CAR like you normally would. DO NOT 'try' to 'drive it so it will reset', just DRIVE IT.
It will be ready after a few trips.
Title Edited to encourage better comments and moved to appropriate forum
Old Aug 10, 2022 | 08:11 PM
WarrantCWO's Avatar
"Did it fail because there were codes or because it was not ready to test?"
From what I understand resetting the codes or disconnecting the battery will require a driving period (50-100 miles more or less) to clear a "Not Ready" indication for some things. In my case it was
Catalyst and Evap. Supposedly this was a safety measure so people couldn't reset the codes and immediately go have their car inspected. This will make some things not ready in the OBDII reader until the car has been through a driving period and sensors do their jobs.
Old Aug 11, 2022 | 10:16 AM
waldig's Avatar
some code readers will show you if it is ready, hope that helps. Woody
Old Aug 11, 2022 | 10:46 AM
Default Re: Emissions: "Not Ready"
Also, when you drive it requires normal driving, not 100 freeway miles at cruising speed.
Old Aug 11, 2022 | 11:37 AM
I'm almost positive this issue is moot since the post is over 1 year old?
Old Sep 9, 2022 | 12:49 PM
Rob M's Avatar
Old thread i realize, but two things to keep in mind when emissions checks are not ready. The oxygen sensor check may never complete if you do lots of short trips. With obd2 diagnostic tool connected, it took me a 13 mile highway trip to get a completed test. The evap check actually requires that you cycle through most of a tank of gas to complete. After a battery replacement it was not ready for well over 200 miles! But that was because i was only putting in a few gallons of fuel at a time and never filling the tank enough. you need to fill up to around 3/4 tank, and then drive to around 1/4 tank to complete that evap check.
Old Sep 10, 2022 | 11:32 AM
A third thing to keep in mind, every vehicle manufacturer has a different way to validate an OBD 'drive cycle', depending on that vehicle, to reset them. Generalizations cover many individual circuit tests within the set drive cycles, but the manufacturers drive cycle will reset if nothing is out of tolerances (defective) within that vehicle. Best to get a hold of the drive cycle, or not. Eventually it'll reset after a few trips unless something isn't working right (out of tolerance).
ryan48
Oct 8, 2008 09:56 AM
Bulldogger
Sep 17, 2008 04:58 PM
Fede_italiano
Jul 30, 2008 08:47 AM
Valk
Jan 11, 2008 09:09 AM
Sennaspirit
Jun 29, 2006 05:41 PM
