Convertible top won’t latch
Old Sep 23, 2021 | 12:53 PM
Bookio's Avatar
Default Convertible top won’t latch
I have a 2005 Crossfire roadster. My top goes down fine and let’s me open my trunk. When I put it up I can’t latch the top to the windshield. The latching mechanism works fine but I can’t pull it down far enough to latch it. The console light stays on and I get a constant beep and can’t open the trunk. Now here’s the kicker. If I let it sit for around 10 or 15 minutes, I can pull it down and latch it but still can not open the trunk with the top up!!! Any ideas?
Old Sep 23, 2021 | 01:24 PM
JSK's Avatar
JSK
Default Re: Convertible top won’t latch
Has anything been done to the hydraulic system recently?
Old Sep 23, 2021 | 02:07 PM
Bookio's Avatar
I had the top replaced and all the hydraulic cylinders replaced over a year ago and everything has been working fine till now.
Old Sep 23, 2021 | 08:21 PM
So, the trunk won't open - sign the lock is still locked because the cycle is not complete.
AND, top wont latch, I'd suppose, due to, again, the cycle did not complete and you have pressure on at least one cylinder, once the pressure releases, the top can be pulled closed, but again, the cycle TECHNICALLY did not complete so the PTCM did not unlock the trunk.
What you must do: CAREFULLY stand back while someone else puts the top up and watch the motions. What does not look right? What seam does not meet it's mating surface as the top goes up? My thought here is a travel sensor on one of the cylinders is not "making" and telling the PTCM to STOP.
This is largely a mechanical issue, you should be able to SEE with your EYES what is not right.
If all else fails make a video of the action and post it here. We need a video that is NOT CLOSE UP, we need to SEE the entire top/car. And sound in the video helps.
Old Sep 23, 2021 | 08:47 PM
Bookio's Avatar
Thanks pizzaguy. I’ll get some help in the morning and try to see if I can spot the issue. If not I’ll video it and post it. Hopefully that’s the problem and you can tell me how to fix it. Is there a way to adjust it to make contact?
Old Sep 23, 2021 | 10:24 PM
We don't know yet, we don't know what the problem is.
Old Sep 23, 2021 | 10:47 PM
Bookio's Avatar
Ok thanks, I’ll post tomorrow on what I find.
Old Sep 24, 2021 | 10:33 AM
Bookio's Avatar
Ok, I’m going to try to upload some videos of the top operating.
Old Sep 24, 2021 | 10:46 AM
Bookio's Avatar
They won’t upload. I’m going to private message you.
Old Sep 24, 2021 | 11:49 AM
Yea, videos won't load here, only pictures. For videos, you must post them on Youtube (or where ever) and just link to them here.
Old Sep 24, 2021 | 01:07 PM
Please let everyone know the cause and solution.
Old Sep 24, 2021 | 01:21 PM
Bookio's Avatar
I got pizzaguy on it, so hopefully I’ll have something to post soon.
Old Sep 24, 2021 | 02:57 PM
Not from the videos you sent. I don't see anything wrong, and you never attempt to latch the top in the videos - so I don't see what you are experiencing.
Old Sep 24, 2021 | 03:30 PM
Yea, this is common. The cycle is not completing and if you look REAL CLOSELY, the top, as it contacts the window frame, is maybe 1/4 inch too far forward to mate with the openings in the frame.
Colleen up in Wisconsin had this happening after they fitted a new top, the new top was not installed exactly correctly.
Let me page Robert McCubbin on this one.
Old Sep 25, 2021 | 10:31 AM
Bookio's Avatar
You are right. I put the top up and observed how far front it came and watched it till the pressure released and it did move back nearly 1/4 inch.
pizzaguy
Sep 27, 2024 10:59 AM
Intimacy
Oct 15, 2017 01:48 PM
willemsen
Mar 4, 2015 10:28 AM
Mofongo4
Dec 10, 2012 08:44 AM
cjb
Apr 18, 2008 03:20 AM
