Putting in my lighted door sills. Need help
Old May 28, 2022 | 04:07 PM
MAYAman's Avatar
Default Putting in my lighted door sills. Need help
Got all my wiring for the sills routed.
the official directions say to use a black/yellow/white wire on the passenger side for power. The only wire like that on the passenger side is a thicker black and yellow wire with white bands.
I wired the grounds to the brown/pink wire on the passenger side.
seems everyone went against the directions and worked from the drivers side.
any help?
Old May 28, 2022 | 10:04 PM
MAYAman's Avatar
Default Re: Putting in my lighted door sills. Need help
What a nightmare. The official instructions were drafted by an absolute moron. Have the ground wires connected to brown/pink and the red wire to black/yellow/white and nothing.
Old May 28, 2022 | 11:55 PM
UrbanE's Avatar
Are you installing a pair of OEM illuminated sills?
Old May 29, 2022 | 12:03 AM
MAYAman's Avatar
yup. I’m now on the drivers side. I unsoldered all the wires on the passenger side even though the official instructions say do it on the passenger side. I’ve extended the power and one of the grounds to reach the passenger side.
again, the instructions were written by a moron.
Old May 29, 2022 | 12:29 AM
That is the wire, black/yellow with white bands, the instructions make sense to me.
Old May 29, 2022 | 01:29 AM
MAYAman's Avatar
I used that wire, it did not function. I’ve achieved success by using the following.
the power wire needs to be extended behind the bulkhead carpet, then you tap and solder that power wire to the Red wire with gray stripe in the wiring bundle along the bulkhead on the drivers side.
the brown ground wires are connected as so. Passenger side tap and solder to the brown and pink wire in the passenger door switch. Extend the second brown ground wire to the drivers side and tap and solder to the brown and gray wire on the drivers door switch.
presto, working door sills. With this knowledge this is really at most a 2 hour job, if that. Do not follow the official instructions, they’re wrong. Also, my sills were labeled incorrectly at the factory lol. They had a left label on the passenger sill and vice versa. You can tell if they’re backwards because the exit hole for the wires has to be on the back of the sill, not the front.
so total **** job by the factory labeling and writing these directions. But got it done and everything is buttoned up. Mine are green to match the dashboard lighting. Blue never made sense. My phone camera created the streaks.
Old May 29, 2022 | 06:48 AM
bc75's Avatar
That looks great. Where did you get them?
Old May 29, 2022 | 09:26 AM
UrbanE's Avatar
Great the hear you got them working. If they have been sitting for a long time not connected, the drivers can fail
I had that happen to one side then both. Had to pull the sills out of the car and remove the guts of the sill and replace the LED drivers and LED light strip with a replacement from EBay.
Old May 29, 2022 | 10:45 AM
MAYAman's Avatar
From the dealer in 05
Old May 29, 2022 | 10:48 AM
MAYAman's Avatar
These we’re modded by timelord way back when he was doing these mods with a 1600 hour being seen driver. It sat in a climate controlled garage since 07 lol, so hopefully it’ll be ok.
Old May 29, 2022 | 10:55 AM
MAYAman's Avatar
I’d like to thank…………nobody here for helping out. Lol 🤦‍♂️ 🤣
jediracer
Sep 29, 2010 06:50 PM
Stogey
Dec 16, 2008 04:06 PM
taroberts
Mar 5, 2008 02:25 PM
Panzer1
Oct 25, 2007 11:49 AM
blacklimitedcoupe
Dec 13, 2006 08:32 PM
