Oil Level Sensor
Old Jun 14, 2022 | 11:41 AM
DeKalb's Avatar
Default Oil Level Sensor
I posted something like this in a different forum, I've gotten help but not to my last question which is ... can I remove the oil level sensor and block off the hole so it is no longer on my car? What, if any, problems might this cause? I know I would need to check oil level with the dipstick ... I already do it this way. I have more trust in the dipstick than a sending unit that leaks and fails at times.
I was going to change the o-ring, but if I can remove the sensor, block the hole, that should reduce any future problems with it ... any help and/or direction is appreciated
Old Jun 14, 2022 | 12:39 PM
DeKalb's Avatar
Default Re: Oil Level Sensor
Think I found my answer after more research ... the Oil Level Sensor is also a Temp sensor so it seems ... I'll replace the O-ring and trust that stops the small leak I have ... Thanks for the help
Old Jun 14, 2022 | 12:48 PM
Ronman's Avatar
"You cannot cheat the level sensor (B40) in your M112 engine.
The sensor in the oil sump is a complex piece of electronics that sends continuous data on a) oil level, b) oil temperature, c) oil quality, to the ME- SFI control unit (ECU).
The data on the 3 functions is processed and sent as a pulse-width modulated, square-wave signal to the ECU and then transmitted via CAN bus to the Instrument cluster."
Old Jun 14, 2022 | 02:47 PM
DeKalb's Avatar
of course ... thank you
Old Jun 14, 2022 | 04:35 PM
philosophico's Avatar
Honestly if you have to remove it to the replace the o ring, I'd just replace it. Look at the age of the car, that sensor will likely be acting up sooner than later. Why do all that work again? When it starts flashing on and off and acting janky, your gonna be paranoid wondering if your low on oil or not. Thats just me.
Old Jun 14, 2022 | 04:56 PM
steve1189's Avatar
From experience, since you have to drain the oil, remove the oil pan and reassemble, replacing the o-ring might solve your problem, but if not, you are doing the whole process over again to replace the sensor. I replaced the o-ring on mine (suggested by a Benz mechanic) only to find out that the oil wasn't leaking around the o-ring. The oil was actually coming out of the top of the sensor! It's not a big job but it is one you don't want to do twice and the sensor wasn't crazy expensive.
Good luck
Old Jun 14, 2022 | 05:16 PM
Ronman's Avatar
I agree with both of you!
That is exactly what I said in his other thread. Then got the annoying pointless "if it ain't broke don't fix it" nonsense line. The heat gets to the sensor and it is a lot of work to just get to the sensor so no point in doing it twice!
The sensor isn't that expensive compared to some other parts.
Old Jun 14, 2022 | 05:21 PM
DeKalb's Avatar
You guys gave me something to think about ... this is what I want, suggestions, opinions, and life experience ... Thank you
Old Jun 14, 2022 | 05:24 PM
Ronman's Avatar
Oil level sensor: 275 905 00 00 Lower pan sealant: 003 989 98 20 10
I don't know if you can away with one tube of sealant, maybe someone else can chime in.
Old Jun 14, 2022 | 06:05 PM
DeKalb's Avatar
Thanks to all on this post ... ordered a new sensor should have it all back together first part of next week ... I'll miss an ACD cruise-in this weekend but will be ready next month ... again Thank You
nelro_PL
Mar 23, 2026 12:44 AM
DeKalb
Jun 14, 2022 12:40 PM
Mtnears
Nov 26, 2019 02:32 AM
David Woolrage
Aug 7, 2013 10:11 PM
Hayabusa1300
May 12, 2011 06:54 PM
