heater blower keeps going
Old Aug 15, 2022 | 12:11 PM
xfiregaz's Avatar
Default heater blower keeps going
i replaced the heater blower resistor a few weeks ago and all was well today went to start car totally flat jump started and fans running on full pelt even with car switched off and key out is it the resistor again
Old Aug 15, 2022 | 01:15 PM
Default Re: heater blower keeps going
Why are you posting in multiple categories? It just makes for confusion and less responses.
Old Aug 15, 2022 | 01:37 PM
xfiregaz's Avatar
cos ain't got a clue what im doing on here first time joining a forum so sorrys for the inconvenience
Old Aug 15, 2022 | 01:44 PM
Could post #3 be your issue? Do you have an owner manual?
recirculation fan will not turn off - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
Old Aug 15, 2022 | 02:10 PM
xfiregaz's Avatar
no not #3 nothing to do with the button being on as all buttons off speed off temp on cold or hot fan still runs even when car locked and i go in
Old Aug 15, 2022 | 07:59 PM
Sounds to me like you connected the battery hot and ground leads backwards and ruined the new part.
The system is simple: The 'resistor' has five wires: a battery feed and ground feed, two wires running to the motor, and a controller wire.
If the controller wire has voltage on it, the motor runs. If there is no voltage on that lead, the motor won't run - unless the 'resistor' is bad.
Old Aug 15, 2022 | 08:00 PM
And WHY the HELL did he not include ALL information in the other thread?
I will blow the other thread away.
THIS is why Im about done helping people.
Thread moved to a tech help section, redirect will stay for five days so no one gets lost....
nickwe21
Oct 9, 2015 12:45 PM
darrman
Oct 18, 2013 08:54 AM
Road King Custom
May 20, 2012 05:06 PM
Kevin P
Sep 21, 2006 07:53 PM
