Grinding Noise
Old Sep 14, 2022 | 10:28 PM
cr007's Avatar
Default Grinding Noise
I'm trying to figure out what is wrong with my crossfire i'm a bit fearful to trust anyone to work on the car because the moment they see it they want to charge 10X because they say oh it's mercedes.
So i'm driving and I hear a grinding noise coming from underneath the center console storage compartment the grinding noise goes away once the car is driving at normal speeds.
upon take off is when I'm experience this issue.
I live in the San Jose, I'm trying to find a good genuine mechanic who honest any recommendations let me know
Old Sep 15, 2022 | 07:57 AM
Default Re: Grinding Noise
Put the car up on jack stands and inspect the drivetrain. Pay attention to the Guibo's and the u-joint, they may have deteriorated. If any of the 'shields' have contact, or too near the driveshaft, it may be rubbing. This simple inspection may save you plenty, let us know what you found.
Old Sep 15, 2022 | 10:23 AM
I think the noise is transferring from either the belt tensioner or the water pump also there are two crossfire's shops in ca look here repair shops
Old Sep 15, 2022 | 10:52 AM
How many miles? I now know of FOUR cars that needed new flex discs, all cars had 150,000 to 220,000 miles on them and three were making noises that make you think the car was falling apart at low speeds.
My suspects are: Flex disc (I think so), differential (probably not) or wheel bearings (really don't think so). And I'd almost bet money on flex disc.
Who will take a $50 bet?
Old Sep 15, 2022 | 11:20 AM
Find an Independent European repair shop the repairs Mercedes and tell them you have the same car as a 2003 Mercedes SLK320.
Old Sep 15, 2022 | 11:33 AM
See, I question if that is really necessary in this case. In this case, I'd bet he has bad flex discs, not hard to replace, they are our car's version of a u-joint.
Pretty low-tech stuff. I used a small garage in Georgia where three brothers and two sons owned the place and worked on cars for fluid changes, brakes, etc.
jamesknox
May 31, 2012 07:42 PM
randyveach
Aug 9, 2009 06:59 PM
GDrag
Feb 13, 2009 02:59 AM
Tom1957BigT
Jul 20, 2008 08:12 PM
wsissy53
Jan 13, 2008 08:19 PM
