Air Conditioning ??
Old Jun 29, 2024 | 07:59 PM
No704's Avatar
Default Air Conditioning ??
I have a 2005 Crossfie, basically a MB320. AC gauges show high pressure on high side and low pressure on low side. So I’m thinking the expansion valve is likely the issue. I have a new one to install. I also got a new dryer. The dryer is a bit of work to install. Would u run the old one or install the new?
Old Jun 30, 2024 | 07:13 PM
No704's Avatar
Default re: Air Conditioning ??
So is PAG 46 a good option for ND-8 refrigerant oil? The ND-8 is hard to find and very expensive. I only need<3 oz according to the service manual for replacing the receiver/dryer.
thx
Old Jun 30, 2024 | 07:14 PM
No704's Avatar
Will definitely be replacing the dryer.
Old Jun 30, 2024 | 11:48 PM
Default Re: Air Conditioning ??
Crossfire A/C refrigerent types
I saw the above article. I hope it helps.
You have to scroll down to the Crossfire section.
Old Jul 1, 2024 | 09:36 AM
HUH?
You did not tell us what the symptoms are nor what you have done up to this point.
Old Jul 1, 2024 | 06:48 PM
No704's Avatar
No cooling. High side is too high. Low side is too low. FSM points to possible expansion valve is plugged up.
Old Jul 2, 2024 | 07:47 PM
No704's Avatar
Question is : can I add PAG 46 to the system or do I have to find ND-8? Seeing conflicting answers to this on the all knowing internet.
Thanks
Old Jul 5, 2024 | 07:04 PM
No704's Avatar
Ordered some ND-8 on line. $30+$15 shipping can’t seem to get a straight answer if PAG 46 is compatible. Little more$$ and time, But some pice of mind.
Old Jul 7, 2024 | 11:39 AM
I posted this before. If you click the link and scroll to the Crossfire section, it looks like PAG 46 is compatible. I don't know **** about refrigerants, so you should verify this yourself.
Link to compatible refrigerants:
CLICK HERE
Old Jul 7, 2024 | 12:41 PM
No704's Avatar
https://www.google.com/url?q=https:/...JrgT-1sCHDElPS
Too many conflicting publications. I don’t know. Already spent the $ for the ND-8. Hopefully this thread can confuse others in the future too. Thanks guys!
Old Jul 8, 2024 | 02:11 PM
I've been confused from the first post (#1). Wish you luck with your repair.
X-MAN
Dec 6, 2009 09:50 PM
big D
Aug 4, 2009 01:05 PM
Crossfireone
Apr 16, 2009 07:06 AM
mack
Jul 15, 2007 09:39 PM
John Webster
Jun 22, 2006 11:53 PM
