Easy way?
Old Jul 19, 2024 | 09:52 AM
Default Easy way?
I have a limited that won't idle, surges and pops when trying to accelerate. I replaced the MAF, CPS and RCM. Is there an easy way to see if a CAT is plugged? Might it be the PCM or throttle body?
Thanks
Old Jul 19, 2024 | 03:10 PM
xintersecty's Avatar
Default Re: Easy way?
If your cat is plugged the O2 Sensors will be indicating an error. The O2 sensors measure the amount of fuel burned before and after the catalytic converter. If you don't have codes check downstream of the converter for plugged up issues. I assume you don't have any codes?
Old Jul 19, 2024 | 04:01 PM
Thanks, actually it did have an 02 sensor code as well as the MAF.
Old Jul 19, 2024 | 04:17 PM
Well that's start. If you had wrote down the codes before parts replacement, can you post those? And then any codes after parts replacement. A bad O2 sensor can mess with the car's performance by poorly metered fuel for the accelerator.
Old Jul 19, 2024 | 05:17 PM
I appreciate the feedback. It had a P0141 02 Cir.1 Bank 1 and P0440 Evap and then a P0101 Maf Sensor. I haven't replaced the 02 sensor yet but it did have a loud backfire. Probably too rich?
Old Jul 19, 2024 | 05:28 PM
OK, yeah replace the O2 sensor. A plugged cat has a strong sulfur smell (google search). It seems weird that you had multiple failures. While you are under the car, you might want to check each O2 sensor. They tend to get "rust welded) to the exhaust. Clear your codes and lets if the car starts behaving.
Old Jul 20, 2024 | 01:59 AM
JSK's Avatar
JSK
I had a CJ7 for 20 years that I installed a tuned port 350 in. Late in my ownership the cat plugged, it ran hot and had no power. No noise and no smell. New cat solved the problem.
Old Jul 21, 2024 | 01:36 AM
I have no clue if this would work or not, just an idea:
Do you know anyone like a plumber that uses a drain scope?
You would have to open the exhaust before the muffler pipe, then send it in.
Old Jul 21, 2024 | 10:59 AM
NeedsWings's Avatar
unbolt the cat pipes and test when open, free
Old Jul 21, 2024 | 11:44 AM
Thank you sir!
Old Jul 21, 2024 | 04:31 PM
Does the Crossfire have four CATs ?
Old Jul 21, 2024 | 07:17 PM
Here's a picture of the exhaust:
Old Jul 22, 2024 | 07:51 AM
That is a great question and if you go looking in the manual it says a three way system.
O2 Sensors
And if you look at the diagram all those numbers are not listed. Sigh.
Exhaust System
You need to go to the parts catalog to figure it out.
Crossfire exhaust system parts
Exhaust system parts list
So I think the answer is yes, the crossfire has four cats.
Old Jul 22, 2024 | 03:28 PM
Thanks !!!
Old Jul 25, 2024 | 10:50 AM
What would cause a crossfire to run too rich? It has a strong gas smell when it backfires? Possible intake valve?
Old Jul 25, 2024 | 03:39 PM
zip439's Avatar
Disconnect the EVAP solenoid valve line coming from the rear of the car, put a little vacuum on it and see if you get gasoline. It is located on the drivers side forward of the ESP/BAS module.
You should only get vapor from the EVAP canister from that line; If you get gasoline, there is your problem.
cppeabody
Nov 19, 2020 04:34 PM
mr.peebody_2011
Jun 8, 2016 07:45 AM
JSK
Jan 27, 2015 06:01 PM
a7x6kse6
111
Jun 18, 2013 10:16 AM
scomer88
Apr 14, 2013 02:55 PM
