Transmission Bulkhead connector
Old Oct 16, 2024 | 11:21 PM
Tazzman's Avatar
Default Transmission Bulkhead connector
What and where exactly is the Transmission Bulkhead connector? Shop says its leaking at this connector.
Shops states this is an obsolete part.
2006 Automatic Crossfire V6 Limited coupe
Thanks
Old Oct 17, 2024 | 07:35 AM
DTMenace's Avatar
Default Re: Transmission Bulkhead connector
Thanks
Tazzman
What type of shop are you taking your Crossfire to for repairs? Your shop is wrong about the part on your transmission being obsolete! The part in question is listed below (1st attached line), and they've been known to fail and leak. You'll need additional parts to do a transmission service on your Crossfire, since your car is 18 years old.
Find yourself an independent Mercedes Benz shop (not a dealer) and they will be able to correct your issues with the leak.
Good Luck....
Dennis
DTMenace
NeedsWings Performance Products. Updated Data Plug Pilot Bushing Transmission Connector
NeedsWings Performance Products. 7226 Transmission Conductor Plate
NeedsWings Performance Products. 7226 Transmission Service kit
NeedsWings Performance Products. Transmission Fill Cap
Old Oct 17, 2024 | 09:35 PM
Tazzman's Avatar
Thanks a bunch I was wondering if that was the correct part. Shop is a local shop but deals with Fords not Chrysler.
Yeah not sure what the transmission needs but only has 20K miles on the car was a garage queen and covered when Not in use.
Old Oct 18, 2024 | 09:02 AM
Wadsworth's Avatar
As DTMenace stated find an independent shop that works on Mercedes. The Crossfire is over 80% Mercedes SLK320. When looking for most parts use 2003 SLK320.
Old Oct 18, 2024 | 01:17 PM
Tazzman's Avatar
Thanks guys.
I feel comfortable in changing out the connector and oil level sensor will have a shop do the rear crankshaft oil seal and the valve cover gaskets.
since the tranny only has 20k on it just like the car and has been kept in the garage do you feel a transmission service while not necessarly needed it would be a good idea just so all the adfitives are current and good.
Old Oct 18, 2024 | 01:38 PM
UrbanE's Avatar
Rear crank seal is a Big(ish) job. The engine and trans need to be separated to do it.
while they are apart, it might not be a bad idea.
if everything ia already open….
i would do it but I have crossfire service OCD
Old Oct 18, 2024 | 07:46 PM
Use this website to find a reputable shop near you.
https://www.benzshops.com/
Old Oct 19, 2024 | 04:16 PM
Nelson G's Avatar
The fluid breaks down, so it is cheap enough to change it. And the plug is easy to replace. You will need a trans dipstick so you can make sure you have the right amount. I did mine, the only problem was the plug did not fit as well, so I purchased another one and the leak went away.
onehundred80
Feb 2, 2025 01:35 AM
Zen Beer
Jun 14, 2023 07:54 PM
roychez
Dec 10, 2021 06:58 PM
scoutmstr
Jul 6, 2009 01:26 PM
pghstochaj
Apr 7, 2006 07:06 AM
