Maintenance indicator
Old Oct 17, 2024 | 12:47 PM
DT123's Avatar
Default Maintenance indicator
Hello, I'm a new user and I just purchased a 2004 X-fire and it didn't come with an owners manual. Attached is a maintenance indicator signal and I'm trying to understand what it means prior to taking it in for service. It has 2 wrenches followed by numbers 9200. The number has changed to 9300 now. Any help would be appreciated.
Old Oct 17, 2024 | 01:22 PM
Default Re: Maintenance indicator
Manuals and lots of info here:
Old Oct 17, 2024 | 02:37 PM
Nelson G's Avatar
It indicates that the car is 9300 miles past its service. When you look in the manual it will have what is indicated to be serviced. Considering you just purchased the car I would say do a full service. When I purchased my car back in December I went through the car. I changed the trans fluid, filter, and gasket, then I bled the brakes and changed the fluid, and the brake hoses due to the age of the car, rear end fluid change, air filters changed, cleaned the area under the front cowl, interior air filter, changed the belts and some of the pullies, sticky key was done, CPS was changed, RCM was sent out to be repaired and a new one was purchased.
This is a good place to start: https://www.crossfireforum.org/forum/585345-post1.html
Old Oct 17, 2024 | 03:18 PM
The way to reset this display ......follow this procedure and it will reset to display "7000" (miles until next service is needed)
RESETTING THE FSS MAINTENANCE INDICATOR AFTER AN OIL CHANGE
1) Move the ignition switch to the “RUN” position
2) Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second The display for the FSS service
request is activated for 10 seconds
3) During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position
The FSS service request will continue to be displayed
4) Press the reset button for the trip odometer and
hold
5) Move the ignition switch to the “RUN” position
6) Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance "7000" appears in the display
The tool symbol should disappear at this time.
Cat Mantra
U.K.
May 7, 2014 10:51 AM
aviram
Oct 8, 2013 07:31 PM
scoutmstr
May 16, 2011 09:09 PM
Chased316
15
Jul 18, 2010 04:12 AM
JetCity
Mar 10, 2005 12:56 PM
