Engine dies at stop lights ... Help please
Old Apr 23, 2025 | 01:59 PM
D. Fuller's Avatar
Default Engine dies at stop lights ... Help please
About 5 times over the last two months the engine has stalled at a stop light. It has always started immediately, until last weekend when it would not start.
About a half hour later, just when AAA arrived, It does not shimmy or shake before dying. No problem the past few days.
Any ideas as to the cause?
Old Apr 23, 2025 | 03:20 PM
Default Re: Engine dies at stop lights ... Help please
Probably failing relays in the RCM, relay control module.
Old Apr 23, 2025 | 03:47 PM
tighed1's Avatar
Could be the Relay Control Module. Send it to me to get it refurbished to eliminate it as the issue.
Email
tighed1@hotmail.com for the details. EVERY Crossfire should have a refurbished RCM or carry a spare!
Old Apr 24, 2025 | 01:49 AM
It could also be your crank position sensor is going bad or as mentioned, the relays in the RCM are bad.
Symptoms: The car dies when the engine is hot, wait 20 minutes then car starts up.
Both are in expensive repairs.
Send your RCM out to tighed1 to be refurbished. He did mine about a year ago and it works perfect. The horn also works without the key in the ignition.
His price is a 3rd of a new RCM and his turn around is very quick. When I sent mine out, I had a spare RCM that I replaced it with until my original one came back.
When I got the original one back, I put it back in and kept the other one as a spare. I'm going to send that one out to be refurbished as well.
Here's a link to replacing the RCM:
LINK to RCM replacement
While your RCM is out, replace the crankshaft position sensor. Use BOSCH only.
Here's a post on how to replace the CPS:
LINK to CPS replacement
Old Sep 25, 2025 | 08:06 AM
Romad's Avatar
What did you find out was the problem? Is it still acting up? We would like to know!
phil alvirez
May 4, 2026 05:35 PM
BrentFerguson
Aug 3, 2012 02:52 PM
pgordon
Jun 24, 2010 02:03 PM
pandableuw
Mar 9, 2010 02:44 AM
pabgarmi
Apr 4, 2008 02:24 PM
