Upgrade Mods Worth the $?
Old Mar 27, 2026 | 04:06 PM
NWGACarGuy's Avatar
Default Upgrade Mods Worth the $?
I am considering whether or not to add a little "Mojo" to my '04 Crossfire LTD by adding the Needswings Dual CAI, and a Eurocharge ECU tune. I have studied the specs and the expected performance gains, and while the added horsepower and torque are not to be dismissed, I wonder if the gains are noticeable (and legally usable) enough to be worth the investment? I have read some threads here in which members praise the improvements, but are the gains really good enough to influence the "Wow" factor? Can they make a noticeable and worthwhile improvement to the performance and handling. I would be interested in hearing from the folks on this forum about their opinions and experiences. The more specific the explanations are, the better (e.g. throttle response, mid-range RPM/MPH gains, ease in manual use of 1st gear and beneficial downshifts, etc). Would like the hear the "Good, Bad, & Ugly" as well as opinions on the value of the money spent for the gains obtained. Thanks!
p.s. I have been a member of many automotive forums, and I have found this one to be the friendliest, most helpful, and expert of all.
Old Mar 27, 2026 | 04:47 PM
Default Re: Upgrade Mods Worth the $?
If you have an limited and you are use to muscle car performance You should just get a SRT-6 and get it over with.
then get all the Needswings performance stuff . with just the bolt on's you can get very close to 350 wheel hp .
and 11.3@ 107 in the 1/4 mile. with the limited you may get14.5 at 90mph with the mods you do to a limited add a little
to that for a srt6 and then $$$$$ and go faster than the most mustangs and or camaro and believe it or not it is faster than a hemi charger .
jim
Old Mar 28, 2026 | 07:30 AM
chriscat32's Avatar
I agree with Jim, enjoy your car the way it is. If you want the wow factor buy a SRT or drop a V8 in it.
Old Mar 28, 2026 | 04:00 PM
zip439's Avatar
Specific to your current car 2004 Limited; Skip the duel intake, use the single Needswings intake, but only if you also use a larger 74 mm throttle body. The car, even with a larger throttle body can not use the additional air the duel CAI can provide; The single is adequate.
A better tune can be had from the Mercedes Swap Shop (there in CA) and also can provide a really nice tune for the transmission.
If you purchase from Needswings get their "oil catch can" right away.
Look at this linked thread it gives info as to upgraded throttle body and a whole lot more: Index
Is it worth it ~~ That's totally your call. I'v done all that and a lot more to my Limited coupe and am very glad/happy I did. I also own a modified SRT 6.
Old Mar 28, 2026 | 04:18 PM
copperfieldkid's Avatar
"If you want the wow factor buy a SRT ..... " - chriscat32
unquestionably! - CFK
nickwe21
Oct 17, 2014 09:42 PM
pburchette
70
Mar 17, 2014 11:05 PM
jobee
Feb 12, 2011 11:49 PM
2005 Ragtop
West Forum
Feb 26, 2010 09:27 PM
RedMountain
Jun 2, 2009 04:43 PM
