Removing a Sirius antenna
The previous owner of my car cleverly mounted a magnetic Sirius antenna on the roof of my car and it has scratched the @#$% out of it. That is another issue, though. Anyways, I'd like to remove the said antenna from the top of my car. Would I be inviting disaster by disconnecting the battery, cutting the single wire running to the antenna, and either capping the wire off or insulating it with electrical tape or something similar (should I have it done professionally by a car audio shop)?
if the Sirius radio/brain is not in the car any longer just cut the wire, it's not connected to anything else. do you know where the "radio end" of the wire is?
only go to the pro shop if you want to just give some money away.
Originally Posted by rock
the radio end of the wire and the antenna wire are connected. Is that correct? I figured the antenna was hooked to a power source or something (other than the Sirius radio).
o55ie18
Oct 5, 2015 05:50 PM
55chevy
Sep 13, 2015 07:38 PM
