another alarm gone wild
Old Mar 28, 2010 | 03:03 PM
typhoon55's Avatar
Default another alarm gone wild
Symptoms:
1. lights start flashing with no alarm sound for no apparent reason
2. when using key fob to disable - alarm siren starts
3.Cannot deactivate alarm with key fob or starting car - only way is to disconnect battery. ( I read several posts where disconnecting battery would not stop alarm but it does.) After connecting battery again, alarm starts after 1or 2 min. usually starting with several dying chirp sounds, then erractic chirps then full alarm again
Car starts and runs fine - I removed alarm fuse and central locking fuse to stop alarm and flashers.
4. Key fob does work except for panic button. only operates flashers - no siren
5. Load test rules out battery
My suspicion is it has something to do with the tow sensors.
Could be the bcm or some other faulty tow module.
I have no warranty so need to narrow it down if possible to repair without dealer
Update: car parked on incline in driveway so when alarm went on I started car and turned it around - after 1 min. alarm went off.
Old Mar 28, 2010 | 08:59 PM
sled driver's Avatar
Default Re: another alarm gone wild
Well as you know I had similar problems last week.
I also ruled out the battery and ensured that everything connected to the alarm where closed (glove box, doors, windows, trunk, gas cap, hood, basically everything that opens or closes). Car is parked in a level garage and since that first night where it went off a couple times I have not had any problems since ... knock on wood. Wish I could help with a solution but I guess it is just all about chasing the ghost till you find something that works. Good luck, and apologize to your neighbors in advance.
Old Mar 28, 2010 | 10:40 PM
Originally Posted by typhoon55
Symptoms:
Tha alarm goes off after 30 seconds normally, but the lights flash for 3 minutes.
Old Mar 29, 2010 | 01:29 AM
typhoon55's Avatar
This time after reversing incline of the car the alarm and lights went off together.
How about when the lights flash forever and the alarm never turns on?
Old Mar 29, 2010 | 10:01 AM
I would try parking it on a level surface if possible, at least then you can narrow down if it is the tow sensor specifically.
Old Mar 29, 2010 | 12:50 PM
typhoon55's Avatar
is the tow sensor / module located in the trunk?What does it look like?
Old Mar 31, 2010 | 08:07 PM
typhoon55's Avatar
looks to be the siren gone wild! So a mal-functioning siren can cause various unexplained alarm phenomena - paranormal type - sick birds on crack, flashing lights etc.
Old Apr 1, 2010 | 06:41 PM
Argh! So mine is going off again. Unfortunately I am in Florida and my wife is in Michigan with the car. Is there a quick fix that I can explain to my wife over the phone. I am thinking something along the lines of pulling a fuse or cutting a wire. It does not need to be permanent just to silence the siren, I am less concerned about the flashers etc going off for a few minutes as long as it is silent. Any help will be appreciated.
Old Apr 1, 2010 | 08:50 PM
I would have her replace the battery....worth a try....
Old Apr 2, 2010 | 11:13 AM
typhoon55's Avatar
pull the fuse - the number is something like 35? last one on the left row of fuses - it is marked as alarm
Old Apr 2, 2010 | 11:21 AM
tighed1's Avatar
My guess from a similar post.
https://www.crossfireforum.org/forum...tml#post477301
Old Apr 5, 2010 | 07:34 PM
typhoon55's Avatar
after removing the siren - there was silence! the lights stopped flashing as well. I never would have guessed that the siren could create the alarm issue. So anyone having similar alarm problems should check the Bosch siren as a possible solution.
Old Apr 6, 2010 | 12:44 AM
tighed1's Avatar
Soooooo you removed the siren and there was silence!?!?!
Now I know how to fix any fault codes I get.
I'll remove that pesky check engine light. Presto magic, no more problems!
Old Apr 6, 2010 | 12:48 AM
bmorgan's Avatar
I wish I had of known this when I got my CPS code. Dummy me.... I bought a new CPS and installed it. I could have just taken the old one out..... Right? Well good information for future codes I guess. JK
Old Apr 6, 2010 | 11:29 AM
typhoon55's Avatar
Sarcasm is a beautiful thing - yet the siren was the problem after all. Silence is golden in this case thou - alarm now works as designed - just with flashing lights only
the fault codes, rear view mirror, who needs them?
Old Apr 6, 2010 | 11:52 AM
Maybe I'm a bit stupid but .... what do you mean when you say only the lights flashing? Does the siren sound when it's supposed to?
Old May 1, 2010 | 09:47 AM
chevyboyac's Avatar
I am havin the same exact issue....tested battery at advance auto parts voltage 13.05 measured cca 724 battery is rated at 640 cca and it was at 74 degrees MEH and i pulled the fuse and im bout to go to the nascar race so I will have to mess with it sunday maybe I am parking it on level ground and its the same issue to every detail as said in the first post, I might replace the siren so I can also get the chirp when unlocking and locking it......ive also let the car sit overnight with the battery disconnect and it still does this.
Old May 1, 2010 | 10:09 AM
trainwreck2003's Avatar
My ridiculous alarm started this issue last week and so I've done the same as others and just removed the fuse. However, this not-having-working-locks and dome light thing has gotten old REAL quick. Where is that blood-sucking horn at so I can at least remove that thing until someone comes up with a solution to what the real issue is?
Old May 2, 2010 | 12:21 AM
The siren is located under the cowl, between the hood and windshield. From what I have read you must remove the windshield wipers to get at it(the challenging part). The solution I have found though research on the forum is to just replace the siren unit. I have not tested it myself yet, as I am in Florida until Wednesday while the car is in Michigan. I will have it done by the end of the week though and will post my results. I ordered the part from http://chryslerpartsdirect.com, the part number is 5124443AB and it costs $151.32. Also I have read that replacing or at a minimum testing the battery can help, apparently our cars go crazy if they are not being fed the exact right voltage.
Also there is a good amount of info on the siren R&R here https://www.crossfireforum.org/forum...lved-read.html
Hope this helps.
Old May 6, 2010 | 10:47 AM
Right on, brother. I surely do appreciate it. It's such a pain in the fourth-point-of-contact not having door locks work with the key fob and not being able to secure the trunk. I'll get on it and see what happens
