No sound from Radio/CD Player
Old Mar 24, 2012 | 10:28 AM
BIGT's Avatar
Default No sound from Radio/CD Player
Can anyone help the Chrysler display appears when the radio/cd player is switched on but when the display comes up for either the radio or CD player I have no sound. I had a flat battery recently and had to charge it not sure if this would have anyuthing to do with it or not. Any ideas?
Old Mar 24, 2012 | 10:45 AM
Default Re: No Sound from Radio/CD Player
Check all the fuses related to the radio. There should be three.
Old Mar 24, 2012 | 11:07 AM
BIGT's Avatar
All fuses checked all ok
Old Mar 24, 2012 | 11:08 AM
Including the one for the amp?
Old Mar 24, 2012 | 11:18 AM
I think there are two radio and one amp fuses under the hood and one fuse on the back of the radio itself.
Old Mar 24, 2012 | 11:27 AM
BIGT's Avatar
I have checked the fuses under the hood on the driver's side not sure where the fuse for the amp is. Do you have to have special keys to get the radio out
Old Mar 24, 2012 | 07:24 PM
Ottawa John's Avatar
Default Re: No sound from Radio/CD Player
Do you get any sound at all? Any "pop" from the speakers when you start the car up? What do you drive? The limited has an amp that has been known to fail, but as I recall only one side would go dead. I didn't bother trying to fix it on mine - I swapped out for a Blaupunkt HU and an Alpine amp - solved all my problems, gave me better sound, and added an mp3 player.
Old Mar 24, 2012 | 08:51 PM
You need these. You can find them just about any good auto parts store, or even Wal-Mart.
Old Mar 25, 2012 | 04:30 AM
BIGT's Avatar
No no sound at all I drive a crossfire convertible. The tracks change on the display for just no sound Someone has suggested I change the amp fuse but I am not sure where the amp fuse is situated Any ideas
Old Mar 25, 2012 | 05:01 AM
BIGT's Avatar
Changed Fuse 23 problem solved Thanks
Old Jun 26, 2012 | 10:36 AM
liberty1's Avatar
Old thread but I just lost sound on the CD only. AM/FM works fine. CD loads and tracks fine. Is the #23 for the CD only?
Old Jun 26, 2012 | 10:57 AM
Nope, for the radio - afraid your CD is dead, means replacement or aftermarket head unit.
You wanted bluetooth for the IPhone/IPad anyway, didn't you ?
HINT: Look for marine head units, they often are available in matching silver.
Example : about $250 for the Clarion M309 with BT adapter from Sonic ...
You WILL have to also purchase an adapter harness and an antenna adapter cable.
Old Jun 26, 2012 | 11:07 AM
liberty1's Avatar
Kinda what I thought. Seldom listen to CD's, like my Sirius/Xm. Time for a new head unit.
Old Jun 26, 2012 | 11:34 AM
Just to clarify and cover all the bases :
Fuse 5 is the switched power to the radio
Fuse 8 is the 'hot at all times' to the radio
Fuse 23 is the switched power to the Infinity Amplifier
Old Jul 7, 2012 | 01:57 PM
liberty1's Avatar
Well disconnected the battery today to do alittle engine work. Anyway after reconnecting decided to try the cd again. I have sound again
TerryR
Dec 13, 2019 03:27 PM
cuziamninja
Oct 5, 2015 10:39 AM
brandoni
Sep 30, 2015 07:48 PM
lazorouss
Sep 11, 2015 09:16 AM
BEATv1
Sep 10, 2015 12:58 PM
