Screen washer problem
Old May 2, 2013 | 07:13 AM
marlam's Avatar
Default Screen washer problem
I hope that I am posting in the right category as the problem is electrical.
My problem is the screen washer sprayer not working, but there is a mini history to this.
Around June last year the “washer fluid empty light” started coming on intermittently. Sometimes it was on and sometimes it was not and it would stay on even if I filled the reservoir completely. During this time the sprayers worked fine despite the warning light. However, at the end of the year (before I over-wintered the car) the light went off completely and the sprayers stopped working. No water and no noise from the sprayer motor (as if the power was cut off).
A friend has suggested to me that it might be an idea to inspect the water reservoir and motor to see if the cause is corrosion of any connectors. He says that normally there will be a plug connector going into the motor and that if this has corroded it will be a simple matter of rubbing away the corrosion from the plug.
Does this sound probable and if so does anyone have either: any experience of doing this; or any photos showing the water reservoir/motor (I assume that the wheel needs removing first) so that I can see what things look like.
Any advice/photos will be very welcome.
Old May 2, 2013 | 09:16 AM
Default Re: Screen washer problem
Not quite the same but very similar.
Old May 2, 2013 | 09:59 AM
marlam's Avatar
Thanks onehundred80: It looks like it might be too much of a job for a non mechanically minded person like me. I am not crazy about removing fender panels, there is big potential for me to do serious damage, but I might take the wheel off and see if fiddling around with the cable does anything. Thanks again.
Old May 2, 2013 | 10:36 AM
The fender does not have to come off, the inner plastic fender is dropped and the tank removed. The picture just shows where it is situated.
My light was going on and off and I found the tank filled with slime and that was restricting the float movement which caused the flashing. I cleaned the tank out and all was golden.
How to remove tank.
Old May 2, 2013 | 03:49 PM
marlam's Avatar
OK, thanks for clarifying that, I was thinking that I need to remove the fender.
Old May 6, 2013 | 03:49 AM
RedCherry's Avatar
Oh. I am so lucky to find this thread. It's clear all my doubts. Thumbs up!
crossfireusa
Oct 28, 2015 12:03 AM
nataliefs
Oct 5, 2015 01:03 PM
skeet370
29
Sep 18, 2015 05:53 AM
smokey847
Sep 15, 2015 10:47 AM
rdougc
Sep 5, 2015 10:30 PM
