OBD Scanner No Power
Old Aug 6, 2024 | 10:55 AM
Wazy300's Avatar
Smile OBD Scanner No Power
I am having issues with my OBD scanner, have tried 4 different scanners, all of which were working, wouldn't even power on when plugged in.
Quite a bit of the electrical work is either New or completely taken out due to the previous owner, My first thought is it could be some simple mistake maybe a misplaced fuse or something of the sort.
The door locks, the wing is stuck up, and the driver's seat won't move, Could it be in relation to such? Only asking as it shows a general service warning when starting, And as of yesterday a Check Engine light.
Any and All suggestions are Much appreciated not mechanically inapt
Old Aug 6, 2024 | 11:02 AM
Default Re: OBD Scanner No Power
Download the service manual free here in the forum, and start there. Look under the electrical system and specifically where the OBD2 port gets it's hot lead from. If there is a hot at it's pin (OBD2 port) then trace the ground back through the return(s). It is a good start for your getting familiar with your car. Also, welcome to the forum!
Old Aug 6, 2024 | 12:21 PM
The wing up, CEL, driver's seat not moving all sound like a weak or dead battery.
Have you tried the OBD with the key on?
meticulousmaynard
May 23, 2023 10:34 AM
Xfirewhiteghost
Oct 12, 2019 10:33 AM
maggy55
Mar 12, 2017 10:30 PM
mottster77
Dec 29, 2012 09:24 PM
caughtNthexfire06
Apr 29, 2009 05:52 PM
