fleece or paper oil filter?
Re: fleece or paper oil filter?
My guess would be that people choose the paper filter because of either the cost or availability. The paper filter costs about $7 - $10, where the fleece filter costs about $14 - $20. I chose the fleece filter because that is what is currently recommended by Mercedes and that is all that the local dealers carry.
zless,
The only reason I am still using the paper filter is because I bought a dozen of them at $9 a piece when I bought the car and will switch when they run out in about six years. Since MB has been using them for years with excellent results in the exact same motor their no need to toss what I have just because the fleece ones came out. Especially since I change my oil at every 5K miles instead of 7K.
Originally Posted by Idaho
zless,
And at $9 apiece... what a good deal you got! It was interesting I was in Kmart last night waiting for Peggy to get done looking at shoes, well I do my best waiting in the Automotive section, but I was looking in the oil filter book, I have bought all my filters from Chrysler for the Crossfire, but I am nosey, anyway I was surprised to see listed for a 2005 Crossfire they had an oil filter listed for our engine along with on available for a 5.7 hemi. I wasn't aware of the option.
on
I was doing a little reading and found that the purpose of the fleece filter is not better filtration, it is longer life. Apparently the standard paper filters were clogging too quickly (for the long service life of the oil) and causing the bypass valve to open, meaning you get unfiltered oil.
So I'd say that if you change your oil more often than the FSS indicates you can use either filter. If you go the whole distance before you change it, use the fleece.
<--- Huge Horsepower
on
I love this forum - Users do some great research!
Thanks,
Bobs
That should keep it out of bypass, but not throw away $45 worth of oil before its time.
Originally Posted by Display_Name
Well then, can we simply change the filter every 3,500 and change the oil every 7,000?
to begin with and be done with it...
jimf
10-10-2015 10:22 AM
