base and limited differences
Old Jun 4, 2007 | 10:38 PM
crossfire6412's Avatar
Default Re: base and limited differences
so kinda going with my first posting does any one know if the cars come "plug and play" for some of the more basic options i just want to add fog lights heated mirrors and the better seats ! i don't need any of the real fancy stuff my crossfire is spending most of its life at the drag way !
Old Jun 5, 2007 | 06:27 AM
bobs's Avatar
Originally Posted by arkady
"both outside mirrors are heated to melt the frost or ice when the Rear Window Defroster switch is depressed." Page 66, the Owners Manual.
Your owner's manual also states the car holds 6.5 quarts of oil. Go ahead. Trust it.
Old Jun 5, 2007 | 06:33 AM
RickZ's Avatar
I can tell you I have put foglights in my base, have not finished wiring them up yet but the headlight switch is fused and operable for the foglights, but the harness isn't wired for them, so you will need to run wiring. I do not know about wiring for the mirrors, but if you do a search there have been others that have put in the limited seats and if memory serves me correctly that is "plug and play". Actually that is why I haven't wired my foglights yet, I am more into the "playing" than "plugging" right at the moment, it's too much fun to drive on nice days.
Old Jun 5, 2007 | 08:10 AM
arkady's Avatar
Since you put it that way...
Old Jul 15, 2007 | 08:36 PM
BullFrog's Avatar
Limited has over the Base the following:
1. Polished aluminum/rubber studded pedals
2. Storage net in the footwell and in the rear bulkhead
3. Heated exterior rearview mirrors
4. Heated seats
5. Cabin air filtering system
6. Upgraded 240 watt Infinity modulus 6 speaker stereo
7. Tire Pressure Monitor
8. Hi-Back seats
9. Cupholder
10. Gas Strut on the Glovebox door to open quieter and smoother
11. Homelink
12. Fog Lamps
13. Silver trim on Windshield Frame, Side Fender Louvers and Door Handles
14. Polished Chrome exhaust tips
15. Silver engine cover
16. Touring Gear
17. GPS (option)
18. Colors other than Black or Blaze Red
19. Automatic Transmission Option
20. Leather Interior
Old Jun 15, 2021 | 12:01 PM
Ddave's Avatar
My first post here. Just bought an '05 base; black, 6-speed. What fun to drive!
Love the straightforward layout, clean gauges, metal shift ****. Form and function are fused.
I would like to add the HomeLink; my inside RR view mirror is wobbly as it is, so replacing the unit with the HomeLink base may be a nice fix/upgrade.
Has anyone done this? Any thoughts or comments appreciated! Thanks
Old Jun 17, 2021 | 08:47 PM
Scott M's Avatar
Welcome, Ddave!
Your question here in this thread is kinda hidden. I stumbled on it by wanting to see the differences between Limited and Base.
I would suggest posting a new thread with your question in the Technical --> Interior forum. You'll likely get some answers there.
Old Jun 18, 2021 | 08:22 AM
Toolman's Avatar
Congratulations on the car purchase, and welcome to the forum. You will find solutions here to most any problem you encounter with the car. And there are many members willing to answer questions.
The Homelink in the Limited is old technology. Myself and others have found it does not work with newer garage openers with rolling codes. You certainly could buy a remote receiver compatible with the Homelink that is wired into the garage opener. Homelink is not part of the rearview mirror. It goes in the headliner. You will need to cut a hole for it. I switched to a very small fob remote that works with the newer openers.
BTW, do not feel bad about missing some of the limited goodies. I own two Limiteds and an SE base which is my favorite. Having the extras is nice, but I don't miss them in the base model. Here are a few observations. The Limited cup holder does not work well, get's in the way of shifting, pops up when bumped with your elbow, and will puncture paper cups. Many owners swap it out with the cubby found in the base. The seat heaters often fail in the limited. I find the cloth base seats are more comfortable and give more headroom. The tire pressure monitors are nice to have, but are old tech in the Crossfires. The cars will not automatically learn new sensors. When the sensors fail it's a headache for owners. Tire shops can clone the old ones if they are still working, but they do not have a scanner that can talk to the car computer to pair with the new sensors.
Old Jun 18, 2021 | 09:34 AM
My two garage door openers use rolling codes and the Homelink works just fine. You have to set them up using different steps to those outlined in the owners manual.
I think they are often called the Canadian instructions as the rolling code feature has been required here for quite a number of years. The instructions are on the Homelink site. I am at this moment replacing the oldest opener as something goes wrong with the signal reception now and again. When it fails to work the button in the car, the outside and the inside buttons do nothing other than make the light on the inside button flash rapidly. There is a self diagnosis system built in but it gives no hint to the problem.
Edit
All three openers are Chamberlains, this last one is model #B550C, it is replacing a model #182671 installed in 2005.
Reading the instructions of the new opener I see that I may require a part called a Compatibility Bridge to convert the signal from the Crossfire to the newer signal used by the new opener. I guess there is only one way to find out for sure. 🙄 Rain today so I guess we will know soon enough.
Old Jun 27, 2024 | 12:28 PM
bossman4's Avatar
I know this is an old posting but I wanted to second that a base crossfire does have an interior cabin air filter.
If you are not looking for it, you are making a mistake.
Old Jun 27, 2024 | 05:20 PM
Edit
That Bridge was required when I installed a new garage door opener about a year ago. But I have the new garage door opener linked to my cell phone, which lets me operate the opener.
Old Jul 7, 2024 | 04:21 PM
Goldwing's Avatar
Neither of my Crossfires work with my Chamberlain MyQ system, about five years old. I picked up remote fobs for about $15/pair. My 2014 Lincoln MKZ and 2018 Maserati Ghibli can work the Chamberlain. I also have a 2011 Audi A4 but I park it in the third bay so have never programmed it for the Chamberlain that I can recall. That bay uses a 25-yo Sears opener. And the Chamberlain works fine with the app on my Android phone.
If someone can persuade the stock Homelink to work with the new(er) Chamberlain MyQ, please post for the rest of us. Thanks.
Old Jul 7, 2024 | 09:04 PM
You need an adapter to make the systems compatible, my SRT does not work with my newer Chamberlain, my '04 Limited did work with my older Chamberlain.
Chamberlain changed their frequency some time after 2005.
You can buy an adapter to convert the new frequency back to the old frequency.
I never bothered and use the new handheld door opener.
Old Jul 9, 2024 | 01:13 PM
Per Dave's comment above, you need a Garage Door Opener Bridge that mounts in your garage somewhere. When you use your older version Homelink system (aka Crossfire Homelink), the signal is received by the Bridge Unit mounted in the garage and it sends an updated signal to the newer garage door opener. Like I stated previously, I just use the app (myQ) on my cell phone for the new garage door opener whenever I'm in the Crossfire. (Note: The app can enable the garage door opener to be linked to my Amazon account. Whenever an Amazon delivery is made, the garage door opener gets a signal from the Amazon driver, the garage door opens so the goods can be placed in the garage & the delivery person closes the garage door when they leave. Garage Door Opener has a Hi-Def camera which allows me to see anyone entering my garage via Wi-Fi. I DO NOT use this feature! NO WAY!!!) For all the other cars, I just bought new handheld signal senders & threw al the previous handhelds in the trash.
Old Jul 9, 2024 | 01:41 PM
bossman4's Avatar
I tried the Amazon delivery to the unattached garage for awhile. It worked well until they started charging $1.99 per delivery for that service.
On my base model crossfire.....
One of these days they might provide the app (myQ) on android auto (carplay) too.
Then that can maybe help justify my small investment in a different car radio.
So then I just need a cell phone, cell data service, Chamberlain garage door opener, house wifi, electric power and the program to open the garage door.
I am almost there.....
Ain't technology fun!
Cashmere210@yahoo.com
Apr 11, 2015 05:03 PM
CharlieO
Dec 6, 2010 03:27 PM
pizzaguy
Nov 4, 2010 04:21 PM
blackcrossfire07
Aug 12, 2010 12:17 PM
Roddy
Apr 30, 2009 05:19 PM
