Engine knocks when I start it
Old Jun 22, 2007 | 06:17 PM
driver1's Avatar
Question Engine knocks when I start it
Hey people,
I have a 2004 crossfire limited that knocks when I start it. It goes away within 5 to 10 sec. but it's loud enough to turn heads in the parking lot when it starts. It seems to be the worst after having sat for 3 or 4 hours.
Chrylser is telling me that it is a normal part of vehicle operation and don't want to repair it. I personally have never heard a car with only 13,600 miles on it knock when it's started so I don't know where they are getting that from. Now they are assigning a mediator to my case to get it resolved.
My question is: Is anyone else having this problem and if so, have you tried to get a resolution to it and what was your outcome?
Thanks in advance for your replies.
Old Jun 22, 2007 | 07:44 PM
Maxwell's Avatar
Default Re: Engine knocks when I start it
Yeah it's normal, but it might get louder at different temperatures, any change in cold weather to hot weather?
I'm not sure if it's piston slap, loud fuel injectors, clutch through out bearing or something else, let us know what you find out.
Old Jun 22, 2007 | 07:48 PM
snowtop57's Avatar
My daughter bought a Hyundai Sonata V-6 with 11,000 miles on it and we also noticed a knocking noise when she first started it. Her problem turned out to be the timing belt tensioner that they replaced under warranty. I'm not sure what we have in our Crossfires, does anyone know if we have a timing belt or chain?
Old Jun 22, 2007 | 08:00 PM
marauderroy's Avatar
I have over 40k miles on my car and there is no knock when I start it. If it's loud enough to turn heads you have got trouble.
Old Jun 22, 2007 | 08:05 PM
RPM's Avatar
RPM
Moderator
Talking Re: Engine knocks when I start it
Mine has not knocked . . .
if it does - should I answer it?
(man that's lame)
Old Jun 22, 2007 | 10:40 PM
driver1's Avatar
"Yeah it's normal, but it might get louder at different temperatures, any change in cold weather to hot weather?"
I just don't see how this loud of knock can be normal. In all the cars in all my life I've never heard an engine knock like this unless it's got 150,000 miles on it or a collapsed lifter or something. It is much worse on hot weather, specifically 70 degrees and hotter. I've have even been told that there is a small puff of smoke out of the exhaust right when she fires up.
Old Jun 22, 2007 | 10:55 PM
Arcrist's Avatar
My '04 with 20k miles does about 4 or 5 knocks at the start and quiets down in a couple seconds. I don't like it but i'm not sure what causes it.
Old Jun 23, 2007 | 06:29 AM
bobs's Avatar
Mine does the same thing, although not loud enough to turn heads. It's done it since bought the car new. I now have 45,000 miles on it and it seems no worse. If you don't trust the dealer, find an independent MB mechanic and ask him to take a listen and tell you if its normal or not. I imagine they would do it free of charge.
Old Jun 23, 2007 | 01:33 PM
Maxwell's Avatar
What kinda knock are we talking about? It's normal to have the ticking sounds, at start up and shut down.
Old Jun 23, 2007 | 01:43 PM
Arcrist's Avatar
its probably just residual gasoline left unburned from when you shut the engine off last.
Old Jun 23, 2007 | 01:46 PM
Maxwell's Avatar
explain that please?
Old Jun 23, 2007 | 04:00 PM
Arcrist's Avatar
Ok, try this exercise and let us know how your engine is working after a little while.
Start your car, rev the engine while at a stop, and shut it off. Let the car sit for a few hours. There is unburned gas on the cylinders that can ruin metal.
Old Jun 23, 2007 | 04:19 PM
Maxwell's Avatar
What kind of metal? And who does this when they shut down their car?
I think your reaching for an answer, but we don't really know what the sound is unless he posts a sound file.
Old Jun 23, 2007 | 07:01 PM
Arcrist's Avatar
I've seen lots of honda ricer kids rev their engine before they shut it off, it becomes a habit, but they do it for the sound. I used to do it on my saturn, not on the xfire though.
Old Jun 24, 2007 | 03:20 AM
intenseblu's Avatar
err knocking ? i get valve train noise... but nothing loud... loud enough to turn heads at least...
sounds very much NOT normal.
Old Jun 24, 2007 | 04:35 AM
driver1's Avatar
If you've ever heard an engine with a collapsed lifter that is the sound I hear. It goes away fast , 5 - 10 seconds, but it is literally loud enough to turn heads. I have gotten several comments from co-workers who have been heading to their cars when I am starting mine. Knowing that this engine is right out of a Mercedes, I find it hard to believe that a Mercedes buyer would have to tolerate a car that makes people look and go "what's wrong with your car?" when they start it.
Old Jun 25, 2007 | 12:46 AM
driver1's Avatar
Default Re: Rev Engine
P.S. I certainly do not rev my engine to shut it off! I will try to get a sound byte of it and post it this week.
Old Jun 25, 2007 | 09:55 AM
xfire2005's Avatar
It is NOT normal to hear an engine "knock" when you start your XFire although it does always have some valve slap noise.
Check your oil, make sure it is full.
As someone else suggested, take it to an independent MB Master mechanic and get an educated opinion.
Good luck and let us know what transpires.
Old Jun 25, 2007 | 09:58 PM
XFireHammer's Avatar
I too hear Valve Train Noise when starting the engine, but not knocking; especially from people passing by!
Something has gone kaput in OsnaBrueck, Germany!
Old Jul 13, 2007 | 12:34 AM
stevules's Avatar
my '04 does the same at start up, dealer of course never heard of it and can't hear it. if anyone gets an answer i'd appreciate it.
