Crossfire console
Old Dec 7, 2007 | 01:37 PM
Beno's Avatar
Default Crossfire console
I have a 2005 Crossfire limited. How do you get the console piece over the cup holder off. Is it just clips or are there any screws. Any help would be appreciated.
Old Dec 7, 2007 | 05:11 PM
danimal's Avatar
Default Re: Crossfire console
I'm trying to understand your question and believe that you are asking about the silver part that you see when the cup holder is closed. I took my cup holder out and replaced it with the storage bin...but, I was just looking at it and it appears that it snaps onto a pin on each side (you should be able to see a small hole on the sides with it open). The problem is the back side which has springs attached and seems to rotate on a rod or large pin. I'm not willing to break it to find out if it will snap off or not. Good luck with whatever it is that you are trying to do.
Old Dec 8, 2007 | 04:43 AM
Beno's Avatar
Its not the cupholder cover. Its the piece that surrounds the cupholder. The larger piece which also surrounds the electric mirror switch.
Old Dec 8, 2007 | 10:31 AM
HDDP's Avatar
Originally Posted by Beno
I have a 2005 Crossfire limited. Ho do you get the console piece over the cup holder off. Is it just clips or are there any screws. Any help would be appreciated.
Here's exactly how you do it !!! Step by Step.
Start with the search button, then follow the directions that have been posted by other members over the past few years... Don't be LAZY ... We have the entire maintenance manual online for your download pleasure...
Old Dec 8, 2007 | 12:29 PM
Beno's Avatar
I can't open the attachment, can you help with this.
Old Dec 8, 2007 | 12:32 PM
Beno's Avatar
Exclamation Re: Crossfire console
The attachment didn't come through. Could you please send it again.
Thanks.
Old Dec 8, 2007 | 01:53 PM
HDDP's Avatar
Oh jeezus, you're kidding me right ? I was telling you to use the SEARCH button on this forum ... Everything has been discussed...
Old Dec 8, 2007 | 03:24 PM
andrew's Avatar
-C-I-C-C-I Associate Member
beno these old posts may help:
https://www.crossfireforum.org/forum...earchid=304949
Old Dec 8, 2007 | 03:46 PM
apkano's Avatar
Life is random...so am I.
HA HA HA ...that's too funny...you kill me HDDP!
I agree with ya...but that's just hilarious!
Old Dec 8, 2007 | 04:30 PM
Beno's Avatar
IT seems your the moron, have a little hart or don't reply.
Old May 10, 2011 | 05:18 PM
magyarwarlord1's Avatar
hey im having the same problem and im looking for this manual and cant find it i to have a broken cup holder on a 2004 crossfire and it stays up and wotn go back downwell stay down i mean. also the window buton fell in and i need to figure out how to get the consol off so i can fix it if u can help it would be nice ty.
Old May 10, 2011 | 05:35 PM
nevermind figured out the serch thingy thanks for the post. I got the whole instructions on how to do it now.
Old May 10, 2011 | 05:39 PM
I wrote up my experiences with a Roadster's console here:
https://www.crossfireforum.org/forum...pholder-3.html
See post 42.
Old May 10, 2011 | 05:49 PM
man my brain isn,t thinking is there any pictures posted on how to take the consol off sorry for being dumb
Old May 10, 2011 | 06:11 PM
ImportLabSRT's Avatar
Go to the sticky for the repair manual. The RM has a step by step procedure.
Old May 12, 2011 | 03:54 PM
Airscape's Avatar
Did you get this sorted out? Found everything I needed using search but basics from memory.
Lift silver plastic around shifter, unscrew 2 screws holding front and rear console together pull up bottom liner in rear bin, unbolt, get some hot water to help lube the Ebrake rubber handle, pull that off. Lift entire console up slowly, disconnect any wires (extra stuff for roadster as explained in above linked post)
There is a thread that has a few pictures from a couple years back. If you still have troubles or can't find it let me know.
massanu
Feb 25, 2018 03:59 PM
BEATv1
Jul 16, 2015 09:40 AM
Mackel
Jun 26, 2015 07:41 PM
BEATv1
Jun 12, 2015 05:20 PM
MJPowers
Jun 8, 2015 02:34 AM
